Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By peter65
Thread: Fuel Sender Unit Installation
    VN S2 Berlina Wagon
    Apr 2004
    Default Fuel Sender Unit Installation
    Just wondering if my fuel sender unit is installed the right way? eg. rotation. etc(see pic)...Because ever since I've had the car I can run out of fuel and then only be able to squeeze 40L back in. (It's a 68L tank). This only happens when parked on an angle but I'm too scared to run it below 1/3. I replaced the fuel pump about a year ago and installed it back the same way but the same problem still exists. When installing the new one there appeared to be no other angle it could be installed on. Any ideas?
    Attached Thumbnails Attached Thumbnails Fuel Sender Unit Installation-img_14623.jpg
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VN S2 Berlina Wagon
    Apr 2004
    thanks mack. Yours is a different setup however...cause it's a v8 i suppose. Anyone with pics from a V6.
    cheers
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by lazza44 View Post
    cheers
    True, but if you look at the electrical connector positions they are in the same spots, same with the fuel line pipe, its on the left pointing upwards slightly. All the other fuel pump pics ive seen are the same. So I say that yours is in right.
    vp exec
    Dec 2006
    vaucluse, sydney
    guys... this might be a stupid question... but assuming that the black hose is the fuel supply to the engine... where is the fuel return line from the engine???? pete
    VP Exec
    Jun 2005
    Via a spigot soldered into the tank towards the RHS. It is very common for them to be damaged and leak. The typical trick is to reverse over something and catch the plastic tank guard visible in Mack's photo's which forces it up into the spigot. The return line into the tank sender was introduced late in the VP model (same as in VR, similar to VS) as a fix.
  1. Fuel Sender MRA Unit??
    By MikesVT in forum General
    Last Post: 19-08-2006, 12:45 PM
  2. Fuel Sender Unit
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 09:48 AM
  3. fuel pump/sender unit re-installation problem
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2006, 05:01 PM
  4. Fuel pump and sender unit
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2006, 12:51 PM
  5. Fuel Sender Unit
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2004, 12:33 PM
