Results 1 to 11 of 11
Thread: Fluctuating speedo needle
    VYSS Crewman/ VX Berlina/ FG XR6T work car
    Jul 2005
    Default Fluctuating speedo needle
    I have just purchased a VPII executive V6 auto. On it's maiden voyage, I noticed that at speeds above about 80km/h, when the vehicle travelled over slight bumps, the speedo needle would drop back momentarily, before flicking back to the correct position. It seems like some type of loose electrical connection. Any suggestions?
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I believe the speedo sender connector is located underneath the car next to the gearbox, its a little white cylinder about 5-6cm long, hop under the car and have a look for it (it may be dirty and not white anymore lol) and take it apart and give it a blow out and put it back together and try again.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    most likely speedo sensor as i had similar problems with mine....changed it no more problems......however i changed it with on i had as a new one was 200 bucks and a secondhand one was 90 but then again i live in a place where the wrekers are ****ing expensive lol
    VN WAGON
    Sep 2007
    mine started to flicker now it has stoped all together i put in another sender unit and still no go..i think my prob is no power getting to the unit to send back the pulse
    VN WAGON
    Sep 2007
    i have the same problem,i changed the speedo unit behind the cluster and speedo sender which cost me 13 bucks and still not working
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    Could quite possibly be a dodgy earth by the sounds of it or a broken circuit board on the back of the cluster or the regulator on the small circuit board inside the cluster has a dry joint.
    VN WAGON
    Sep 2007
    VP Executive R-spec
    Jan 2005
    Speedo sensor fuse in the panel under the steering wheel, you can thank VN Luke since he told me what it was when mine broke
    VN WAGON
    Sep 2007
    is the black wire screwed in under the steering column the earth for it also as its loose
    goose2's Avatar
    goose2 is offline 40. the new 20
    VT BerlinaWagon/VZ exec wagon
    Sep 2004
    Ballarat, VIC.
    if the speedo sender unit(on the box) is replaced I'm sure the problem will be gone .there was a thread a while ago on this subject basically the electrical current is interrupted and it cant share the pulse with the ecu. happened to me some months ago now less $400 and 4 demerit points but it works now,$33 at wreckers
    If i wanted to break ya balls i woulda kicked ya girlfriends handbag
    VP Exec
    Jun 2005
    It's an old(ish) thread but to check the sensor itself:
    1) Unplug the speed sensor connector at the transmission.
    2) Wire the pink/black trace wire on the sensor to battery voltage (run another wire back to the battery).
    3) Run another wire from the black/white trace wire to earth.
    4) Connect a test light between battery voltage and the violet/white trace wire.
    5) Rotate the driveshaft and the test light should switch on and off through the sensor, if it is working correctly.
  1. VR V8 BT1 Speedo Needle Below 0km/h
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 08:08 PM
  2. wobbly speedo needle
    By Lish in forum General
    Last Post: 19-02-2006, 12:55 AM
  3. speedo needle not functioning
    By bluecar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 10:06 AM
  4. speedo needle dances!!!!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2005, 05:07 PM
  5. speedo needle
    By superchargedv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2005, 04:12 PM
