In the middle of putting a new loom in the VN, but I cant find matching plugs for the following... So any help with what they are would be awesome
These SHOULD plug somewhere near the glovebox area as the plugs are located in the same spot as the wires for the glovebox light and remote boot release:
http://img175.imageshack.us/img175/1...vqloom1tv2.jpg - Anti Theft Module
This one however was already in the car lol It is above the ECU, not sure where it should go??
And also...
What the hell is this, it is in the glovebox :S:
http://img171.imageshack.us/img171/956/whatisitjz1.jpg
the glovebox...thats a refrigerated unit...i think it runs off the aircon??? not sure tho...u can keep things cold in there. a mate had one in his vr stato.
-George
lol I wonder who came up with the idea to turn a glovebox into a fridge?
Those green and white plugs look like they are for the BCM/Anit-theft module. That usually hides under the dash above the glovebox. Not sure about that 3 pin plug though
3 pin plug is a economy/power switch connector or at least a vr/s uses one of these for it.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
As above ^^^^^ the anti theft module.
and 3 Dangerous non ABS VN's
Ah excellent. Not sure what to do with the 3 pin plug now though? Its out of a 91 VN Calais so not sure the economy/power switch connector :S
Thanks heaps for the help guys![]()
Thought i'd chuck up another few.
Light for immobiliser or something perhaps... Comes to centre console area... No not gearstick light:
Connects to this about 10cm down: http://img219.imageshack.us/img219/7...nlight2jy6.jpg
Now as for these im thinking brake switches for Cruise Control? Comes out to under the steering wheel:
And lastly this... Single green wire.. Runs off past the cluster connectors:
Security light in first pic, is right. The 2nd pic I would go with you on that one but that last one I'm not sure.
