Results 1 to 8 of 8
Thread: after market steering wheel made steering crap!
    vp executive
    Nov 2007
    lakes entrance VIC
    Default after market steering wheel made steering crap!
    today i put on my autotechnica steering wheel and bosskit
    took her for a drive and it was horrible like i had no p/s vibrated like hell and making a grinding noise every time i moved the wheel
    i have done it properly as i had in all my previous car's
    i can now turn the wheel half turn and the wheel's only very slightly move about and inch and before full turn was lock this has me very puzzeled
    has anyone with a vn/vp had this problem before?
    [SIGPIC][/SIGPIC]
    Screw the icecream...
    Who wants a moustache ride?
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    I guess it could feel a little heavier because its smaller then the stock wheel?
    Australia. Love it or leave it
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The boss kit would be too far down the shaft and fouling on the column I would say. Either the collapsible part of the shaft is pushed in or you have the wrong boss kit.
    Visit my Facebook page
    vp executive
    Nov 2007
    lakes entrance VIC
    so i could loosen off the bosskit and pull it forward and do it back up?
    what if the collapsible part of the colum is pushed in?
    it is the right bosskit its brand new and i went to autobarn and got the part number out of the book myself as the sale's assitant didnt know how to read all the number's properly
    and it is the same size maybe a few mm smaller then stock
    [SIGPIC][/SIGPIC]
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you look at the back of the boss, you will probably see it is worn a bit where it was touching the column.
    To pull the shaft out a bit, put the old wheel back on, put the nut on a couple of threads and then use the wheel like a slide hammer to pull the shaft out. It may only need to come out a couple of mm. These get pushed in when people hammer the shaft to get the wheel off.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    I remember reading that if the collapsible part of the column is pushed in, you have to get a new steering column?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Well...technically, yes. But if its only a couple of mm then it should be fine to pull back out.
    vp executive
    Nov 2007
    lakes entrance VIC
    its all good took the bosskit and the tab on the back that turns the indicator off had grinded into the copper wire stuff about half an inch from a 5 minute drive!
    i was a bit ****ty so i grabbed the pliar's and snapped it off chucked the s/wheel back on and took it for a burn problem fixed but i have to turn the indicator off myself now lol
    also the colum was in a few mm to far so i did the thing with the stock s/wheel and pulled it out a bit much better to drive even before i got it as it had been in a prang and probly hadnt been fixed
    [SIGPIC][/SIGPIC]
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Will A VY Steering Wheel Fit VS???
    By Wagon_Wheel in forum General
    Last Post: 12-10-2007, 09:16 AM
  3. Getting the steering wheel off!
    By kizza231188 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2007, 10:49 PM
  4. vx steering wheel
    By Burnout_bro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2007, 08:21 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
