Results 1 to 7 of 7
Thread: replace sensor on climate control VN
    vn s-pac v6 series-2, vp v6, vr berlina v6
    Sep 2004
    Default replace sensor on climate control VN
    is it possible to replace the temp sensor on the climate control unit itself? the incar temp sensor thats attached to the actual climate control unit behind the little grill on the lower right of the unit? can that sensor even be baught?
    cheers.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I don't really know but I would think you should be able to replace it.
    MY RIDE
    mwb235 Guest
    For VT/VX yes it can be replaced - the GM part number is 09152245 (yes that's the correct number), current price $48.18 retail.
    You can also buy an "Ambient sensor repair kit" (new sensor plug) part number 92144967, current price $22.74 retail. This replaces the plug that plugs into the sensor itself. Apparently water can get into the plug (causes a short circuit) meaning the outside temp reads too high. I've just fitted the new sensor plug and the oustside temp seems to be reading correctly now. Let's hope the f-kken thing stays that way this time!
    I have no idea if the two part numbers i mention above can be used on other models or not.
    Sep 2004
    yeah my outside (a,bient) temp reads fine it must be my inside temp thats why i think its the sensor thats on the actual climate control unit itself in the dash. the actual unit with the buttons and siplay on it has a sensor on the bottom of it ( a tiny thing) if i could get a new one i could remove the old one and solder a new one on.
    mwb235 Guest
    Do you mean VR/VS or VT/VX?
    If it's a VR/VS (see PIC #1) then AFAIK you cannot buy a replacement resistor/sensor as such, only the whole unit, as the sensor is actually part of the whole assembly. Surely you could get one from Dick Smith or similar, remove the old one and solder the new one in etc, but i have no idea what exactly you'd need and what resistance/rating.
    If it's a VT/VX/WH (see PICS #2 and #3) then i assume yes you can buy a replacement - it's a small black plastic assembly that is under the dash surround, to the left of the steering column, where the small oval-shaped vent in the surround is. The one in my pic was out of a wreck and it doesn't have any part number stamped on it - just ask your local Holden Spare Parts folks, assuming its still available new they should be able to order one in for you.
    Attached Thumbnails Attached Thumbnails replace sensor on climate control VN-pic-1.jpg   replace sensor on climate control VN-pic-2.jpg   replace sensor on climate control VN-pic-3.jpg
    Sep 2004
    spot on man with the VR/VS picture. thats the exact resistor/sensor thing im after. i might remove it and take it into dickys and see if they have something i can use. i dont want to replace the whole unit if i can help although if i see a cheap second hand one somewhere.
    mwb235 Guest
    Quote Originally Posted by stackner View Post
    There's a few secondhand VR/VS ones on feeBay atm if you're interested. In 04 or 05 (when i still had my VR) i was quoted $450 for a new one from Holden.
    btw maybe you could get a VT/VX one from a wreck and unsolder the sensor from it, then solder it into your VR/VS unit? Just a thought - you'd have to be sure though they are the same rating/do the same thing etc otherwise it won't work.
  1. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  2. Replace light in Climate Control
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2008, 03:44 PM
  3. Wtb: Vr/vs Climate Control Outside Ambient Sensor
    By Summer-Sickness in forum Swap / Wanted to Buy / Trade
    Last Post: 15-01-2008, 07:40 PM
  4. Climate Control - Exterior/Ambient Sensor
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2006, 12:31 AM
  5. How to replace climate control buttons
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 10:54 AM
