Results 1 to 12 of 12
Thread: vl diff head into vn
    vn,vl
    Jan 2008
    Default vl diff head into vn
    hay all,just wondering if a vl 3.46 diff head would bolt into 1990 vn diff housing as my 3.08s are abit sad.
    VT feature car, WRX STI WAGON
    Aug 2006
    vn,vl
    Jan 2008
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Quote Originally Posted by kiwivn View Post
    Fits no worries, that's what I have in mine at the moment.
    VP Executive R-spec
    Jan 2005
    Mar 2006
    NZ
    ^^ Ah yeah forgot about that, (good opportunity to convert it to LSD) else you can keep the VN 28 spline centre and bolt the 3:45s onto it.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    how many splines does the 3:08 have is it alot of work to convert it yourself
    ~ VN POWER ~ Click the scales
    VP Executive R-spec
    Jan 2005
    All VN's have 28, it's a bit of work but hey, worst case it breaks and you need only need to get a cheap VN diff to stick back in
    Black VN MANUAL
    Feb 2007
    Top of Vic
    could you put a full VL diff in the VN? would you have to change the tail shaft or just bolts up?
    VP Executive R-spec
    Jan 2005
    The complete diff assembly bolts in but you have to make mini tubs and run really big rims for it to make sense (the VL diff is an inch narrower on each side) . The VN Group A ran a VL diff with mini tubs. You don't need an engineers for mini tubs either
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Bz Kn33z View Post
    Single spinners are easy to change never done a lsd so cant comment there but done heaps of single spinners and heaps of centers with a mini spool in them they are the best thing just not real good for road use.
    Jun 2006
    Western Aus.
    VL diff is 40mm narrow all up compared to a VN diff.
    Depending on what rims you are running to how well it will fit. I've got SV 5000 rims on my wagon and slotted a VL Wagon diff straight in with no drama's at all. But that probably has something to do with the SV 5000's running a VL width diff anyway so wheels fit in the guards perfectly.
    Last edited by FusionX; 16-01-2008 at 10:05 PM. Reason: Don't know why I quoted someone.
    Hot Lap Motorsport
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  3. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  4. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  5. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
