Results 1 to 3 of 3
Thread: having problems with my vn
    1990 VG ute 3.8 auto
    Mar 2007
    qld
    Exclamation having problems with my vn
    hey guys
    im having some troubles with my vn
    1 my thermo fan does not work at all sometimes it does work very little
    2 car overheats (water boils up in bottle )
    gear lights not working ie p r n d d 2 1 light doesnt turn on if you gus know anything that could help please let me know thnks guys
    vn engine parts pm me
    VP Exec
    Jun 2005
    The problem with light around the gearshift will most likely be that the globe is blown. It wil be easy to see and fix by just removing the trim around the gearshift (it simply pulls out, with 2 clips on either side).
    If the thermo fan isn't working, that will cause the overheating. The fan should be working with the A/C on. If it isn't, you can look further. Putting a jumper wire across the terminals (on the car) switched side of the relay, pins 87 and 30, ignition on, will tell you if the fan is working OK or not. If it is, try another relay (one from another circuit on the car will serve for the purpose of testing) or you're looking at the switching side of the system which involves the ECM and associated wiring. One possibility on this side is the coolant temp. sensor.
    If the car is leaking coolant somewhere, that can also result in overheating.
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    The water boiling up in the bottle sounds really strange. Are you sure it is boiling and not gas coming from a blown head gasket? If it's gas you have a serious problem.
  1. VL has problems has anyone had this before?
    By garysvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-05-2007, 09:11 AM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. oil problems
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 09:56 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 03:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 12:04 PM
