Results 1 to 13 of 13
Thread: VN Pod filter housing
    89 VN Executive 3.8i
    Oct 2007
    Default VN Pod filter housing
    I was thinking of removing the K&N filter and replacing with a pod filter.
    I've seen pictures of a street legal skyline the had the left front headlight removed and instead it has an air intake hole and am wanting to do the same with my car, and having the hole lead into a housing for the pod filter.
    Would alluminium be alright for the housing or would it not shield against heat? And would the pod filter provide better air intake than standard K&N filter?
    HOw is having a headlight removed street legal?
    [SIGPIC][/SIGPIC]
    Come on down and see the idiot right here.
    You aint up to Fudge all buddy
    mischa's Avatar
    mischa is online now <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    It could be street legal and the light was only temperley removed for a drag. As thats were the intake is.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Basically, on a stock V6, you're going to get more performance gain out of the standard airbox with a high flow filter and a cold air intake, than with a pod filter anywhere in the bonnet. Unless you construct yourself a fully enclosed pod filter housing which runs into a cold air intake, it's going to be counter-productive. The difference between hot engine bay air on a day like today, and ambient air which could be up to 50 degrees cooler, can be up to 5hp or even more.
    Pods are good for use with a supercharger or turbo, because they have a higher flow, and heat up the air anyway... but that's about the extent of their benefit. Your V6 should never flow more than a stock panel filter can handle. I know mine doesn't
    I've done G-Tech runs with my panel filter in, and with the panel filter removed altogether... I just run a CAI, and I noticed no difference in times with or without the filter.
    The 1972 HQ Kingswood
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    My old V6 setup. K&N pod in the air box with CAI.
    I have more pics but cant find them. I ended up sealing the thing up with hot glue gun.
    Morton's Avatar
    May 2006
    Classy.
    Oct 2007
    Yeah thats what i was thinking of.
    The reason i wanted to do it is for the noise of the pod filter but i was told Cai of the K&N was better, i just assumed a pod filter with a housing would be like Forced Cold air intake.^^'
    [SIGPIC][/SIGPIC]
    Oct 2007
    Quote Originally Posted by Morton View Post
    You should do a few consecutice runs without the filter and tell me if anything bad happens.
    [SIGPIC][/SIGPIC]
    Morton's Avatar
    May 2006
    Nothing bad will happen. I know a bloke who runs his lancer filterless 24/7 'cause it's a thrashcar. But I wouldn't run without a filter for an extended period of time on a good car, because dust and sand will get into your motor - and you run the risk of fine grains of sand turning into glass and shredding piston rings and bearings. Nothing worse than contamination in the motor
    89 VN Exec, 94 VR SS
    Dec 2007
    An idiot I know 'forgot' to reattach his pod to the intake pipe from engine so he had an intake pipe coming from the engine and nothing attached to the end, just a hole and he reckons it went hard lol
    Oct 2007
    I ran mine with just the hose for awhile when i stacked my car, it whent pretty hard maybe just because i was giving it ****. i put a sock around the hose though.
    [SIGPIC][/SIGPIC]
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    To tell you the truth, with all the effort I put into doing mine on the V6, it wasnt worth it. Just run the OTR CAI and a standard pannel.
    Oct 2007
    OTR? over the radiator?
    [SIGPIC][/SIGPIC]
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Quote Originally Posted by FuzzayD View Post
    Yep OTR = Over the Radiator
  1. Thermostat Housing
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2009, 07:58 PM
  2. vk diff housing
    By Panama in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-12-2007, 09:01 PM
  3. VR thermostate housing
    By com05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 09:00 AM
  4. thermostat housing
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 09:26 PM
  5. Air Filter housing
    By spazvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-03-2006, 06:23 PM
