Results 1 to 16 of 16
Thread: hand brake banging noise
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default hand brake banging noise
    Hey, my cars done this since i got it, not sure weather its a IRS issue or what,
    sometimes when taking corners the hand brake (in the rotor drum) go BANG like as catching on the rotor for a second, ive take the rotors off and cant find anything wrong
    also if your driving along and pull the hand brake on it goes bang and stops doing it for a while
    do i need new drum things or rotors?
    the sounds ****ing me off but its not dangerous and not getting worse
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    when u raise the h/brake in an IRS car it will bang (whilst driving that is)....ill tell u more about this when i see you....not too sure about when its doing it when you take corners tho.
    -George
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    my vp used to do that after i started entering corners on the handbrake!
    I also noticed that if i'd pull it up just gently while driving it'd go "TUNK" then you'd be able to pull the handbrake without any crazy noises while moving.
    As far as what caused it... I got no idea.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah luke i remember when we went for that drive in the vp your car did it too right before a u turn,.. that exact noise, i know if u pull it lightly it goes TUNK then it quiets down.
    its got me stumped
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    I don't think there are any contacts on the axle or anything?
    handbrake is basically a drum brake inside the discs.
    two shoes which can be adjusted inwards or outwards, they're held in place by a whole bunch of springs etc.
    best bet would be to get new shoes (they crack and break away if you gank the handbrake up while driving a few too many times), and get replacement springs for the mounings.
    from there make sure it's adjusted as far out as possible without rubbing, and see if it helps!
    IT might be made a bit more difficult because your drum could have a pit worn into it form the handbrake, which makes adjusting a bit more difficult, but you should still be able to access it from the back with everything in place throuhg the little hole ine plate that mounts on the diff.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah ive seen the springs and shoes
    i dont assume they'd be terribly expensive, i should just replace them
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Mmmm... I've always wondered what that clunk was. Sounds like someone slapping a couple of brake rotors together
    The 1972 HQ Kingswood
    VN Wagon
    Feb 2005
    We always get that clunk during motorkhanas. I suspect it is because the shoes are somewhat "floating" and so when you use the handbrake the shoes move a little bit in whichever direction the car is moving until they hit the plate. So if you stop on a hill facing up (rolling backwards a bit) the shoes move back a bit. Then when you move forward and pull on the handbrake the shoes move forward a bit and give you the clunk. Once the shoes are set in the one direction the clunk goes away until you move in the opposite direction. So during a motorkhana if I'm fussed I'll start in the garage by pulling on the handbrake gently which gives me a clunk. After that all handbrake action is relatively quiet except the screaming of the passenger.
    I also noticed that the handbrake lever travel changes depending on which way the car is moving.
    As far as your clunk when the car is cornering I would slacken off the cable and set the shoes to specification, then readjust the cable.
    VP Executive R-spec
    Jan 2005
    Can't say I've ever heard this in the VP. But I did have a mystery noise in one rear wheel for a little while but it cleared up
    89 VN Executive 3.8i
    Oct 2007
    I had this in my vn, my hanbrake spring and button and small metal line thing all flew out one day and i ended up replacing it with a vp handbrake. The only thing i touch was the hand brake cable and what holds it onto the handbrake and i havent heard that noise since.
    [SIGPIC][/SIGPIC]
    Come on down and see the idiot right here.
    You aint up to Fudge all buddy
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    intresting but i dont think its the button,
    pete, did you ever fix the issue? or just put up with it as you cant notice it over the passenger? heh
    VN Wagon
    Feb 2005
    Quote Originally Posted by PaRaDoX616 View Post
    No I just accepted it. Technically you normally don't apply the handbrake when the car is moving.
    mischa's Avatar
    mischa is online now <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by TurboXS (Pete) View Post
    should of told my mum that while i was driving on the highway
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ARE YOU SERIOUS? i brake into ever corner using the hand brake
  15. #15
    Oct 2007
    Quote Originally Posted by FuzzayD View Post
    I noticed this week that i still have this problem. ****!
    [SIGPIC][/SIGPIC]
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ahh dam, im going to replace the pads & springs, its the only rattle / noise left in my vp..
    i have the quietest VP around i reckon no interior plastics rattling, nothing falling apart hehe... yet anyway...
  1. hand brake adjustment???
    By hbdvysute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-09-2008, 10:15 AM
  2. strange banging noise
    By fishman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2007, 07:29 PM
  3. Banging Noise VK
    By Mr Robbo - The General in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2006, 01:32 PM
  4. Drive Wheel Banging Noise!! HELP!!
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2006, 09:30 AM
  5. hand brake
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2004, 07:26 PM
