Results 1 to 19 of 19
Thread: VN turns over by itself
    MiSs MeOw's Avatar
    MiSs MeOw is offline MiSs MeOw
    spankin 1998 VT
    Feb 2007
    Default VN turns over by itself
    ok guys WTF............. when i connect the battery, the car wants to turn over by itself??? checked all the earths and nothing is touching, im baffled and its doing my head in
    WTF???????????
    vn calais, vs clubsport #137
    Jun 2005
    lol i guess its just started doing this? you havnt just re wired anything on the ignition side? sounds like youve bridged the wiring for the starter somewhere.
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    Quote Originally Posted by vn calais manual View Post
    havent rewired anything at all, it did start this by its self as my husband drove up the drive way and it stalled, went to start it again and it wouldn't start,
    anyway he had a look around and found that the main power wire going to the starter and the little single wire had melted together from it being against the block, so we changed that part of the loom and yer now its trying to start by its self,
    we've changed the loom with 2 diff one's from the orig and it still is doing that same thing...........
    All i can think of now is Auto elec
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Maybe it fried the ignition switch. It could be melted inside so that there are terminals or wires touching. Unplug it from the barrel and have a look.
    Visit my Facebook page
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    The single wire that goes to the starter motor is the trigger wire that makes the starter motor kick in when that gets power. I would say that it has melted somewhere further back in the wiring and getting constant 12 volt power
    This would explain the car trying to start all the time
    If you have a multi meter you could try removing the main power to the starter motor and testing the single (trigger wire) to see if it is getting constant power
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Maybe the starter motor solenoid is stuck on ??
    Remove the trigger wire to see if it still wants to start.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    mmmm ok ill try that single wire in the morning and see what happens
    thanks guys its really doing my head in lol
    vz wagon
    Aug 2006
    Wild west of Melb
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    see i was thinking it wouldnt be the loom coz we've changed it thats whats making me confused but ill try the solinoid wire thingy tomorrow
    and if that doesnt work ill get out the hammer lol **curses and hits the engine**
    89 VN Exec, 94 VR SS
    Dec 2007
    Reminds me of a prob I had in my old VC, for some reason one day the car just kept auto accelerating at about 30km and it wouldnt stop even with the H/brake on it would be almost taking off. the problem fixed itself the same day but nothing cause it and i did nothing to fix it, it just stopped. Pretty cool to have a car you just have to point and brake
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ok guys i unplugged that purple wire to the solinoid on the starter motor, attatched the battery and it didnt start to turn over by itself and there is power to everything now,
    so now my question is how do i figure out where the purple wire to the solinoid is getting the power from???
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by goddess View Post
    Have you got a circuit diagram ?? Follow the circuit back from the starter. I would take a guess that now the starter motor is ok, the next place to look would be the starter motor relay (if there is 1).
    http://woteva.tk/
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    we dont have a circuit diagram
    yeh starter motor is all good and the starter motor relay is all good too
    is there another way to check where the power is coming from?
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    You are looking at a VN V6, try here http://www.memcals.com/pdf/VN_V6%20Wiring%20Diagram.pdf
    Just looking at the starter circuit, there is not much that can go wrong.
    EDIT: oops, just saw you had a VN V8. http://www.memcals.com/pdf/VN_V8%20Wiring%20Diagram.pdf
    http://woteva.tk/
  15. #15
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the purple solenoid wire gets power from the starter motor relay in the fuse box above your battery, swap relays over with a similar one, if its not that then chances are your ignition switch is faulty and sticking at START instead of ON
  16. #16
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ok guys, my husband found where the power is commin from its commin from the relay called "LP CHK" wondering what does that mean?? and is it ment to be commin from there?? if not what would i have to do to change it??
    Cheers guys thanx for all your help.
  17. #17
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ok now my husband is askin the plug that connects to that single purple wire, is it ment to split into 2 one going to the "START" relay and one going to the "LP CHK"??
    He's tryed switchin relays and still the same thing, he's getting 12v from both the "START" and "LP CHK" Relays, is this right??
  18. #18
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    he's worked it out, it was a relay, the LP CHK one what eva that one is so its all good now i think
  19. #19
    vn calias v8
    Sep 2007
    yeh had this problem with my landcruiser once was very lucky car was in gear in the driveway and 2 oclock in the morning heard a huge thud and the car had propelled forward into the house while trying to turn over itself . lucky my kids werent near it at the time or at a carpark somewhere. try telling this to the insurance company . it just started to turn over by itself and smashed through my house .lol. any way turned out to be moisture in the computer. got in through the door seals try your computer.
  1. car turns off
    By BOXTROT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 01:15 PM
  2. air con / fan cant go to 4 (turns off)
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 06:15 AM
  3. car intermittenly turns on
    By kluckmeister in forum General
    Last Post: 08-01-2007, 09:24 AM
  4. VT turns over but will not start
    By brettm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 01:02 AM
  5. Help. Air con fan turns itself off
    By veeque92 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 06:57 PM
