are vn v6 discs the same size as vn v8 discs i have an ss and rda have said they are.The pads on the ss hang over the edge of the disc by 15mm
1986 vl berlina turbo
1981 te gemini panelvan
there are about 3 sizes for the vn / vp v6, which ones?
thanx for the supply i rang hem and argued the fact that the didn't fit and they went through there catalogue again and apologised they didn't see the ones for the vn V8 sedan which is the 190mm disc not the 170mm
290mm. The VN V8 and the VP V6 with FE2 take the larger rotor, the rest take the 272mm I think it is. There are two different original thicknesses too, 22mm and 23mm.
thanx fo all the help guys problem has been fixed by RDA . got the right rotors and an apology for there screw up
