Results 1 to 3 of 3
Thread: Transmission swap
    Jan 2008
    Default Transmission swap
    Hi,
    I have a VN 90' v6 with a OHDM code transmission, the transmission is rooted as it takes 2hrs to go into gear and rattles too.
    I picked up a transmission off ebay for $50 and was told it will go in the VN, well the code is 4HDD which i have looked up and found its from a VS v6.
    can anyone confirm if it will fit ok and if anything is needed extra when swapping transmissions like new mounts, seals, bolts etc.
    I will change the drive shaft seal and the oil tray seal and filter.
    Thanks in advance.
    Stuee
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Well, if it's an auto box your talking about (I don't know what codes mean what) but from VR onwards they were electronic gearboxes, so I think you're gonna need to change the ECU or the memcal, though I think ECU is the same, so maybe just the memcal.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    no it wont work, 4HDD is from a 1994 model VR and wont work with the VN computer... you need a VR computer and transmission wiring loom if you want top run it.... sell it and get a box TH700-R4 box out of the VN....
  1. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  2. Replies: 2
    Last Post: 27-09-2006, 11:29 PM
  3. Bizaare Swap: Vn Transmission
    By saint_matrix in forum Swap / Wanted to Buy / Trade
    Last Post: 17-06-2006, 10:49 PM
