Results 1 to 19 of 19
Thread: Overflow Bottle Empty?
    GIMPY1's Avatar
    GIMPY1 is offline Bass Slappin Mag Designer
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Exclamation Overflow Bottle Empty?
    hey guys,
    once again, me being the dumb**** i am needs help! my car has been running a lil hot as of late so i poped the hood to find my over flow bottle is empty? is it spose to be? i have pleanty of coolant in the coolant bottle. im just mega confused at the moment!
    Cheers for any help!
    Quote Originally Posted by elmaso View Post
    maybe the guys really wasted, like 24/7, you know how booze can some times lead to hookin in with some fugly chick, well thats probably what happened with him and the car.
    GIMP Mobile V2.0 - In Progress
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How is the cap on the coolant bottle? Change that first. $8 is cheap.
    Visit my Facebook page
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Quote Originally Posted by Not_An_Abba_Fan View Post
    im guessing its not sposed to be empt.... its got a lot of residue built up on it, might go buy a newy! could there be any other reason this is happening, im not loosing water either...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You are losing water. What happens is the coolant expands when warm, goes into the overflow, when it cools it gets sucked back into the main bottle. If the cap is buggered it will let too much coolant into the overflow and it overflows out of that onto the ground when you are driving. Then when it cools and gets sucked back, it will totally empty the overflow bottle.
    vn executives
    Sep 2005
    hi, where can I get it. my cap is not very tight and lose coolant in this way.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    coventrys auto one mals any auto store lol just give them a ring to see if they have one first. amcap too
    13.3 1/4 exhaust only untuned!
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    cheers for the help guys, ill go buy one tonight
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Quote Originally Posted by gimpy21 View Post
    bought one at lunch today and i still have the problem... could it be my collant sensor?
    VS SSBodyKit
    Sep 2005
    Default i have same problem
    Same on my '95 VS.
    Temp gauge is never very high but sometimes after a drive coolant is dumped out of coolant bottle as it fills up to the cap.
    When I look at radiator coolant is always up to radiator cap , temperature is low but reservoir bottle empty!!
    Im a bit confused as to what might be causing this.
    Does anyone out there know how this system is suppose to work as im pretty sure the reservoir coolant bottle is full only when engine is warm.
    Thing thats got me buggered tho is the engine temp gauge is never above half!!
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There is a cold and a hot level. The cold level is lower than the hot level. For too much coolant to be forced out into the overflow, it will either be the cap or a buggered thermostat. The cap is the cheapest and most common problem. I would say the thermostat isn't opening.
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    hey guys... bit of an update. it turned out to be a blocked radiator. took her to the shop today so its gettin fixed a we speak!
    91 VN SS 355
    Feb 2005
    WEST SUBS
    that'll do it atleast you have a new cap they would have put one on ur radiator anyway.Cost much?
    Cheers.
    * RVN 355 *
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Quote Originally Posted by RVN 355 View Post
    dont know yet.... i gotta pic it up after work. my guess is around 300. could be worng or i could be right.. at leats the problem is fixed!
    91 VN SS 355
    Feb 2005
    WEST SUBS
    $300 you can get a brand new vn radiator on ebay with 2 year warranty For $120.00
    Cheers.
    * RVN 355 *
  15. #15
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    the problem is having time to install it as i work 7 days.... money is not an issue i just want the bloody thing fixed! but thats good to know for future reference!
  16. #16
    VP exe
    Sep 2007
  17. #17
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Quote Originally Posted by Just_a_stocker View Post
    get it flushed
    will be sweet then
    considerd that.... they tried it and it wouldnt flush so i told them to chuck in a new one
  18. #18
    VS SSBodyKit
    Sep 2005
    Update: My problem was fixed when I added a new radiator cap. when I added some quality coolant to the engine I made sure I didnt OVERFILL the system. The previous owner might of overfilled the system just before selling me the car aswell which didnt help.
  19. Default
    the op had an s1 v6, so the cap on the coolant bottle is the equivalent to the radiator cap on your car anyway. what do you mean by overfilling the system? the only overfilling you can do is filling up the overflow too much - and worse case scenario the first time you drive your car the overflow bottle will overflow and the excess coolant will be lost... causing no damage...
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. V6 overflow bottle used in ls1????
    By vtwgn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2008, 09:23 PM
  2. overflow bottle ??
    By bradvt98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2007, 04:16 PM
  3. overflow bottle
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2007, 08:25 AM
  4. overflow bottle
    Last Post: 17-01-2007, 11:14 PM
  5. Changing Radiator Overflow Bottle to a Washer bottle
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2006, 02:12 PM
