Results 1 to 5 of 5
Thread: Stuck seat in VP!!
    VY SS
    May 2005
    SA
    Angry Stuck seat in VP!!
    Can't get the seat out in my VP! A piece of metal has broken off where the seat attaches to the rails leaving the seat loose as a goose, moves back and fowards all over the joint (as in the entire seat not just the base or the back).
    Trying to take the seat outta the car, but can't get the allan key threads to budge attaching the rails to the floor pan, have been able to loosen one up with the help of a mash hammer, flat head and some wd 40, but it just spins firmly and aint gettin anywhere.. Any suggestions? Are the seats normally difficult to get out? Cheers guys
    VP Executive R-spec
    Jan 2005
    Nah they come out easy with some good allen keys and something on the end of the key to get some more powaaaaa. They are full of loctite tho so it takes ages to wind them out . You can choose to either be
    A. A patient Monk, relax on the floor and slowly undo it
    B. Unlesh all your anger and put maximum powa into undoing it in a wild rage
    Probably takes the same time either way
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    It's certainly frustrating, especially when the others have come off easily
    I used a hex key socket on mine and it does make life easier but had one that was a right pain, Berlitza05, his old man and myself spent a few hours trying everything to get it out, in the end we cut that bit of the rail off as I wasn't re-using my old seats anyway
    It was just turning a little on it's own but would not come up any higher once it hit a certain point
    So quick fix if you don't need the seat rail is to hack that bit off and then hold the broken bit right up against the bolt as you loosen it, if you need the rail intact then I wish you good luck as if it's anything like my one you're in for a fun time....
    If ignorance is bliss why aren't there more happy people around ?
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by s_pack View Post
    it also helps to do work on your car in the day time not @ 11:30 @ night
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    i used an allen key with a piece of copper pipe about 25cm long as a breaker bar....worked a treat and they came out no worries!!!
    -George
  1. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  2. CD Stuck
    By VZCalZone in forum Car Audio
    Last Post: 26-04-2006, 11:48 PM
  3. still stuck in the 70s help me
    By mutant in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 08:59 PM
  4. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
