Results 1 to 7 of 7
Thread: CAS and Crank pulley
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    Default CAS and Crank pulley
    Well, I learned something today. Course, all you bright sparks out there most likely know this already. But I will repeat it as it bears repeating.
    VR crank pulleys do NOT fit VN engines. And, VR CAS does not fit either.
    So how did I find this out? I took the car to a wrecker who fitted the parts to it. He didn't tell me they were of a VR but it most likely would have gone over my head anyway. After all, they are basically the same engine. Why wouldn't they work?
    Well, I have to tell you they nearly do. But evidently there is a problem with the timing when you do it. Mine had this huge vibration just as the throttle was advanced. I took the car to the Holden agent and they came up with the diagnosis.
    So it's back to the wrecker who fitted them. He can sort it out.
    Went back to the wrecker and they changed both. Vibration is gone. Car starts OK. On to the next problem.
    Just a question. Can a series 1 VN pulley and CAS fit and work OK on a 91 V6?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i was under the impression that the CAS is the same right through all the 3800V6 range and even the VS (ecotec)but i guess that could be wrong. next time i'm at holden i'll have a quick look see through there parts listings
    Body by Holden, Soul by Brock
    the Legend will live forever
    VP Exec
    Jun 2005
    Quote Originally Posted by IvegotaCommy View Post
    The balancers are different between S1 and S2 VN V6. The early type is a slip fit on the crankshaft and the later one a press fit, for a start.
    VN Executive
    Oct 2007
    The CAS is different between the series 1 and 2 and the VR. The series 1 is set using a feeler gauge. The series 2 is set using a special tool (AU423). Not sure if this indicates physical differences or is just procedural. The 90/91 VN has an extra shroud which makes feeler gauge setting impractical. The VR has no adjustment at all.
    VP Executive R-spec
    Jan 2005
    Ah delete that I didnt read it straight
    But I thought all the cas would be the same
    VN Executive
    Oct 2007
    Well, everything is going great. Vibration is gone and I can now drive down the road without the car needing a tow.
    There is just one thing I don't understand. Originally I changed the harmonic balancer because it was noisy. The replacement was a VR pulley and it worked. No vibration and no problems. So then I put the thermostat in and the working temperature of motor went up to normal. That's when the problem showed up of not being able to start the engine for half an hour after stopping. So then I replaced the CAS with the VR CAS and that's when the problem with vibration showed up. So, if it's as you say, that the CAS are all the same, why did it show up then? I mean, if the incompatibility was the pulley, why didn't it show up when it had the (original) VN CAS in it?????
    '91 VG Ute
    Nov 2011
    Tamworth
    Sorry to dig up such an old thread, But I have a bloke coming around in the morning to pick up a few parts and he's looking for a harmonic balancer for a series 1 VN.. However the engine parts I'm selling are from a series 2 VN... I've heard 2 different stories.. #1. the harmonic balancer is interchangable if the correct bolt is used.. #2. It is interchangable if the CAS is changed to suit.. Can anyone confirm this? I don't wanna sell him a part that won't work.. Cheers
    Do it once, Do it right!
  1. idler pulley arm
    By daron in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 10:48 PM
  2. Tensioner Pulley ??
    By DaveSch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2007, 03:01 PM
  3. pulley bearings
    By Stretchomatic in forum V6 Development And Modification
    Last Post: 05-01-2006, 11:21 PM
  4. Harmonic Balancer / Crank Shaft Pulley
    By knight97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2005, 07:38 PM
  5. Knocking Sound From Crank Pulley
    By patto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2004, 11:10 PM
