car was fkning up on tha way home, stalled twice!!!! on tha main highway
did a code test and its tha crank angle sensor
i need to no how to clear that code, so i can do a new test
and also wats a decent price to get it changed (labor and parts) need to no wat to pay
cheers
Remove the engine fuse for 10 seconds, or disconnect the battery.
CAS should be around $45-$50, labour to do it shouldn't be any more than an hour. $70-$80 depending on the rate.
cheers mate
just rang ultra tune and a small auto shop, they said 180 and 160 respectivly for parts n labor
spose i should ask this aswell, since tha weekends startin
how much drivin can i do with it buggered? i mean if i dont get tha engine temp up too much should i be alright? or is it jus guna continue stallin on me? cause i wont b able to get it booked in till mondai at tha earliest, but i gota drive to work n sht on tha weekend![]()
Drive at your own risk is what I will say. It can be random, it may not do it for a week, or it may do it 10m down the road.
ye and just my luck it will happen to me, i gota drive to work both todai and tommorow
thankfully good old melbourne weather, its raining and cool, so hopefully the temp wont get up enough to cause an issue, my works only five minutes down the road so i should b sweet (knock-wood)
