Results 1 to 5 of 5
Thread: MAT sensor query, dumb question
    VN EXEC
    Dec 2006
    Default MAT sensor query, dumb question
    hey all,
    just a quick question, if the voltages are too low and too high 4 the MAT sensor does it mean the sensor is putting out too much or too little, or does it mean its getn too much
    better question does it mean it will fix itself wiv a new MAT sensor or is it something else? cant find a thread similar to it so cheers guys
    Stevo
    VN EXEC
    Dec 2006
    well i tried a new MAT sensor, its saying that the code is still 44, which is too low im pretty sure. its still coughing and farting and it says its running too lean, is there another way it will get low voltage readings???
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    Dunno, but my book indicates the code 44 is Oxygen Sensor, not MAT sensor.
    For the oxygen sensor has codes 13, 44 and 45.
    Code 44 seems to indicate problems with weak mixtures (i.e. the oxygen sensor thinks the mixture is weak).
    Code 45 seems to indicate problems with rich mixtures (i.e. the oxygen sensor thinks the mixture is rich).
    Could still be the MAT but could also be several other things.
    VN EXEC
    Dec 2006
    my bad code 44 is the result of it leaning out, but the mat sensor circuit is still having dramas
    VP Exec
    Jun 2005
    Another resistance eg. poor connection, corroded wire, in the circuit will cause the voltage seen out of the sensor to be low.
    If you want to check the sensor:
    100C = 185 ohms
    70C = 450 ohms
    38C = 1800 ohms
    20C = 3400 ohms
    Something else: If it is missing (ignition caused) that can set a lean exhaust code because uncombusted air (O2) is going through the exhaust.
  1. another dumb question
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2009, 11:51 PM
  2. Now i no this is a dumb question lol
    By V3N0M in forum The Pub
    Last Post: 24-07-2006, 05:44 PM
  3. Dumb question about IRS
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 06:10 PM
  4. Sensor query...
    By Flamenco in forum Electrical Wiring / Questions
    Last Post: 10-01-2006, 08:31 PM
  5. Really dumb question
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 06:23 PM
