Am having major problems with '91 VN. Car was parked for a few hours when the headlights came on and horn started blowing til it blew the fuse. Switches were not turned on. When I jumped started the car, headlights were still on and cant be turned off unless i take out the fuses and during the drive home, a buzzing noise could be heard either from behind the instrument panel or in the column, not quite sure, but the noise stopped while indicating to the right. Left hand indicator light on dash was permanently on, even tho indicator stalk was not in use. Heard that it maybe headlight or horn relay, but I would be grateful of any advice you guys can give me to solve this problem. coz I have no idea!! Thanks
you need a new indicator switxh by the sounds of it.... dunno about the horn tho??
I'd agree with peanuts on the combination switch,when you say the headlights are on,hi or low beam?,does the switch feel right or is is stiff and notchy ?
Phillip![]()
