hi all hope someone can help me with this problem im having with my beloved commodore.
i dont seem to be getting any fuel up to it. i have changed the fuel pump so that is not the problem. im not sure what else it could be can anyone here give me any ideas.
fuel up to where.. mate people need a bit more info....
is your new fuel pump actually kicking in... you havnt just blown the fuse?. or shat a relay. check these first.
fuel up to the injectors. no i havent blown a fuse and the relay is fine
are you getting it in and out of your regulator...
no its not flowing at all ive tried putting an extra electronic fuel pump on still no fuel flow
have you checked the filter? can you hear the pump running?
You could try looping out your diagonstics plug, with the key being in the on position slide under the car and try to listen for the fuel pump.
If that does not work and you can not hear anything then get a multimeter and test the white plug that comes from your car to the fuel tank sender and see if that has any power there.
If there is power there then eaither your pump is blocked, a wire has came off the pump inside the tank or it has just died.
This will tell you where to start looking for your problems
no but i have another filter should i try changing it. i didnt think that would have anything to do with the fuel flow
thanks for all that info mate
the filter has alot to do with fuel flow.
Yeah, fuel filters are directional, I dont know what happens in you put it on backwards, but im guessing its not good for flow.
