Results 1 to 13 of 13
Thread: VN Brake problem?
    EF Almost Turbo
    Jun 2005
    Default VN Brake problem?
    Hey
    Was driving dads car yesterday (VN V6) and i went to brake, but the pedal almost went down to the floor and all I heard was a grinding noise.. I just missed the car infront of me.. but the brakes have worked perfect since... only problem with the brakes at the moment is the rotors need changing (they are a little warped)..
    Any ideas?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ratz26's Avatar
    ratz26 is offline worlds oldest noob
    2001 VT equipe
    Sep 2007
    tweed heads
    that may be why, warped rotors aint a good thing, but by the sounds out it i'd lean more towards air in the brake line... so i suggest bleeding ya brakes..and get them rotors replaced...$20 each at a wreckers
    vn calais, vs clubsport #137
    Jun 2005
    or $40 brand new.......
    sounds like air in your brakes. bleed them and put some decent fluid back in. make sure you bleed in this order
    Rear Left hand
    Rear Right hand
    Front Left
    Front Right
    ratz26's Avatar
    2001 VT equipe
    Sep 2007
    tweed heads
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by ratz26 View Post
    just a dumb question is their a reason to bleed brakes in that order?
    yeh its best to do it from the furthest to the closest wheel as if ya do it, lets say, front right.. back left etc... you can run the risk of more air (if any) entering the lines
    ratz26's Avatar
    2001 VT equipe
    Sep 2007
    tweed heads
    VP exe
    Sep 2007
    Jun 2005
    brake rotors being warped will give off a bit of a shudder under decel and braking.
    try bleeding your brakes if that fails id be looking at your master cylinder leaking into your booster perhaps.. it happens.
    EF Almost Turbo
    Jun 2005
    Yes it shudders on braking.. not on decelleration tho.. and the pads are fine..
    Ill bleed them tomorrow and see how it goes... cheers guys
    DaZ
    The_Monk says:
    im a leech
    Jun 2005
    if its shuddering then youll need to replace them. bleed your brakes, and get some new rotors and seing as your pads all alright you should be braking properly in no time.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Without actually looking at the car it would be difficult to pin point the problem.
    If there was air in the system, the pedal would be soft all the time. The thing that is a concern is the grinding noise accompanying the soft pedal. Check the thickness of the material left on the pads, if it was thin then the pad may slip out of its correct position in the caliper giving a long pedal travel and the grinding noise. It may have popped back in when you released the brakes.
    Visit my Facebook page
    ratz26's Avatar
    2001 VT equipe
    Sep 2007
    tweed heads
    just a thought...with ur rotors being warped the pads would be wearing to match that warp, maybe you should consider replacing the pads as well
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Pads don't really wear to "match" a warp. They can match grooves but not a warp.
  1. brake problem
    By Matt_vp in forum V6 Development And Modification
    Last Post: 06-01-2007, 06:15 AM
  2. Brake Light Problem!!
    By 08_adaml in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 09:15 AM
  3. Brake problem
    By c_dowlo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2006, 01:51 PM
  4. Brake Problem
    By FINCH in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2006, 12:37 PM
  5. Brake problem
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2005, 09:42 PM
