+ Reply to Thread
Results 1 to 19 of 19
Thread: Why are you beeping at meeeee!
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Question Why are you beeping at meeeee!
    My level 3 dash is beeping at me for some unknown reason
    Its like 2 beeps then 3 quick beeps... When im driving or taking off or idling, whenever it damn feels like it!
    Does anyone know or have a list of reasons why the cluster is meant to beep so that I can cross them off one by one?
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    hmmmm maybe it thinks u have no fuel....
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Hand brake can do it - Have you got a VN Calais cluster?? I had 3 in the wagon over a short time as one kept beeping - found out it was a VP cluster.... So I pulled the little round beeper thingo and we played cricket with it and beep no more...
    and 3 Dangerous non ABS VN's
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by VLDavo View Post
    Nah it did that on the way to the servo and the light flashed with the fuel icon
    Quote Originally Posted by 88GreenVN View Post
    lmao
    Not handbrake either Cluster im not sure on... Its meant to be a VN Calais one but as I did not remove it from the vehicle myself (bought it off ebay), I cannot be 100% sure.
    Im liking the cricket idea though Where abouts is the beepy thingy?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    lmao
    Take the lens off (3 scews) as you look at the front bottom centre. Small round silver thingo (5 cent diam) and about 10mm long and has 2 little prongs on it. - when you unplug it.
    Easy as to rip out..... and it goes a long way if you hit it just right
    VN calais 91
    Aug 2005
    most likely an electrical issue or a short somewhere
    i'll be driving along, and the fuel, spd and coolant light will start flicking and beeping at me
    then stops, then starts again
    check all the plugs. it helped when i changed the battery terminals as they were old as hell
    Cobez's Avatar
    Cobez is offline LS-EXUAL Cobez has disabled reputation
    2004 S2 VY SS Ute
    Feb 2007
    I have had the same deal on a level 2 cluster, the attention light comes on (the one that looks like the shape of Victoria with an exclamation point in it) for well over a year now, nothing has gone wrong really.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Is all the wiring behind the cluster on the ok? I mean not shorting somewhere? Mabye need to resolder something in the cluster?
    Also do lvl 3 clusters beep when you throw a fault code???
    Jun 2005
    Quote Originally Posted by Cobez View Post
    you mean the one shaped like an engine? your engine light?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by stocky View Post
    No he means the one shaped like Victoria LOL! I should check mine and see if its the shape of QLD.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by stockies View Post
    I dont think so? Although mine hasnt thrown a fault code since I replaced the o2 sensor.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    No, looks more like the shape of Victoria to me. I'd hate to have one shaped like QLD though, may as well just slam my car into a wall and get it over with
    Yeah the engine light has been going on and off for over a year now. No probs. It seemed to do it after i had the chip tuned. Apparently it's a common problem.
    VN v6 s2 Berlina 5spd
    Mar 2006
    Haydz's Avatar
    Haydz is offline Go Fast or GTFO! Haydz Berlina
    VS UTE L67 T5
    Nov 2007
    Liverpool.Sydney,NSW
    i also had the same problem. about a month ago. holden in all theyre smarts must have wired some sort of relay. because if your handbrake globe isnt connected properly you will always get a random beep. i drove with it for a month until i worked out the problem. but this was on a vr same thing i think. if not just try all the possibilities. there are about 6 let me know if you want them i have them in a book. somewhere.
  15. #15
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Its common after people install pacemakers and exhaust, its got to do with the oxygen sensor not heating up enough.
  16. #16
    Vn Commodore S pac.. MANUAL!!
    Sep 2007
    Endeavour Hills
    i had the same problem just last month.. one of the tracks for the handbrake is probably craked an it thinks that the handbrake is on or somthing.. i just scratched the paint off an re connected it with wire...its a bit more complicated then that.. but it never does it anymore.. if you need any help just pm me.. cya
  17. #17
    Sep 2007
    Endeavour Hills
    awww yea an if case you think im a dodgy guy.. it was my dad that did it an hes an electrician so if you need any help just let me kno
  18. #18
    VN calais 91
    Aug 2005
    a friend of mine who worked at holden said that the engine light (The orange one with the ! in the middle) could be related to the o2 sensor
    mines been going on and off for a long time now
    what really bugs me is i'll be driving, and the park brake, coolant and one more
    will come on and just flash like nuts for no reason
  19. #19
    padrickz88's Avatar
    padrickz88 is offline Rick =] padrickz88 Maloo padrickz88 Maloo
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by timmy_tam View Post
    does the lights dim? it obviously doesnt have enough power to run the cluster when this happens because it happened to me when my alternator was on its way out, exactly like you said.... except i got stuck on the side of the road at 3am 1 suburb away from my house
+ Reply to Thread
  1. beeping in the cluster
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 16-11-2007, 02:57 PM
  2. Whats causing the beeping!!?
    By PsYko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 01:12 AM
  3. Stupid Beeping!!
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2007, 03:05 PM
  4. vl beeping?
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2005, 03:15 PM
