Results 1 to 3 of 3
Thread: 70mm throttle body install
    VN V6 Commodore
    Jan 2008
    Default 70mm throttle body install
    gday i installed a bigger throttle body into my VN and attached it to a K&N Air filter.... When i fire her up it idles very high unfortunatly i dont have a rpm gauge so i cant tell you how high. What should I do??
    thanks
    vn calais, vs clubsport #137
    Jun 2005
    did you clean the t/b before fitting it? you havnt stretched your throttle cable have you, havnt tried adjusting that?. did you swap your idle solenoid from your old throttle body over?
    89 VN Exec, 94 VR SS
    Dec 2007
    Have you tried resetting the cpu?
    Discon battery or the fuse and wait 10 secs for battery,5 min for fuse
    recon it, rev your car to 3000rpm for 10-30 secs, should hopefully reset itself and idle normally?
  1. V6 & V8 70mm THROTTLE BODY
    By Blown V6 Hatch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2006, 12:12 AM
  2. 70mm Throttle Body
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2005, 07:12 PM
  3. 70mm throttle body
    By jdjones in forum Parts And Other Items For Sale
    Last Post: 10-10-2005, 12:24 AM
  4. 70mm throttle body upgrade
    By jdjones in forum V8 Development and Modification
    Last Post: 23-09-2005, 11:48 PM
