Results 1 to 5 of 5
Thread: vs adjustable steering column into vn?
    VN Calais 5ltr
    Aug 2005
    Default vs adjustable steering column into vn?
    ive got a steering column out of a vs here, will it fit straight into a vn?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Would be a great idea if it bolted straight up but it doesnt...some mods are needed where it goes through the floor ....pinion input shaft splines that the coupling attaches to on the actual rack are different too.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If you do proceed with the change, then you will need to obtain an Engineers Certificate that will show the modification complies with any ADR and is in fact safe.
    VN Calais 5ltr
    Aug 2005
    ye im not goning to worry about it, i was only going to do it if it was a straight swap
    VP exec ser2 wagon
    Aug 2005
    can't you use the vs outer housing with vn inner parts?
  1. Adjustable Steering Column for VN??
    By Lexx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2006, 06:38 AM
  2. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
  3. Steering column adjuster
    By Roh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2006, 02:34 PM
  4. steering column key lock Help
    By sherr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:11 PM
  5. VR Adjustable steering column
    By Scholtzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2005, 11:45 AM
