Results 1 to 14 of 14
Thread: Few questions about suspension
    VP V6 Executive
    Jul 2005
    Default Few questions about suspension
    Ok so I got a bit of cash saved up as I was doing a lot of over time over the Christmas season. Anyway I was thinking about getting a bit of work done to the VP. First Im prob going to chuck a bit of cash towards getting all my suspension replaced as it’s very soft.
    Ok so my first problem is. Im running 18’s, 235’s, that came off my boss VY SS…
    Anyway im having issues with rubbing. It’s not so bad now as I got some spacers on. But my questions are. If I decided to get my car lowered will I get any more rubbing then what im getting now or was getting before I got the spacers on…
    Also how much do you guys think I would be looking at to get my ****ty old suspension replaced… what did you guys pay??
    Thanks guys
    Nick
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I would say part of the issue with the scrubbing would be incorrect tyre size if they are the same sized tyres as used on the SS. Im talking profile, not width or size. I run 19" 245's with heaps of room at the back. Also, wheel spacers are illegal. What is the tyre size?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Is your car IRS or live axle? The offset is slightly different between the IRS and Live axle cars.
    In Victoria wheels spacers are not legal unless your car was fitted with them OEM. To my knowledge no Commodore have ever been factory fitted with spacers. Heaps of people fit late model wheels to early commodores and most have the issue you are talking about. Be careful as your car may not be insured if you have a blow out and accident as these are not legal modifications
    Check out http://www.vicroads.vic.gov.au/NR/rd...340/0/VSI8.pdf. Item 8, Wheels and tyres.
    Reaper
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    I went out a while ago and had a full Pedders sports ryder kit fitted with front strut brace, for a bit over $1500 all up. Had it lowered so the bottom of the rear outer guard sits a tiny bit lower than the top of each rear tyre. Basically tucking a bee's penis worth of tyre.
    I run 18's with 235/40's front and rear and have no problem with scrubbing, but i am waiting on some money to come through either today or early next week, then i'm going out to buy a set of sigs (19's) and try and run 245's on them and see how it goes.
    But i got away with not lowering mine too much because it has a full bodykit fitted, so it makes the car look alot lower than it really is. If you have no kit and want that low stance, you actually have to dump it real low.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    strhsv is offline strhsv
    VN Berlina 5.0L '89
    Oct 2007
    I also had a full Pedders sports ryder kit with front strut brace for about $1700, But i went really low. 45mm of ground clearance at the lowest point
    which is at the extracators. The next lowest point is 95mm which is the
    fuel tank. 18" wheels with 265's on the rear. This does rub, but only with a
    full tank of fuel (90L, berlina tank). The rear guards are also flared
    So you can go as low as your comfortable with and what your budget allows.
    But i think your car cant be low enough and your wheels big enough.
    Check the pic..
    Attached Thumbnails Attached Thumbnails Few questions about suspension-new000_0003.jpg
    don't be a fool, rap your tool!!
    Reaper's Avatar
    Aug 2004
    I truely hope you neither live or drive anywhere near me. Ever wonder why the regs are like they are?
    Reaper
    Quote Originally Posted by strhsv View Post
    Check the pic..
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Can never be too low? Of course it can. Mine isn't silly low, and mine still scrapes on the odd occasion on a driveway. It's sh*t. Bodykit and bigger wheels will make your car look a little lower though. Hence why i didn't dump mine on it's a*s. I don't really want the underbody of my car scratched up and rooted.
    89 VN Exec, 94 VR SS
    Dec 2007
    Hmm too low is a problem, my vn has a kit and lowest point from side skirt is 120mm probably 90mm at the muffler. The car already came that way when I bought it but I wouldnt change it now.
    Speedbumps are an issue, I try to avoid them completely also my exhaust scrapes a tad when im leaving home unless im going real slow. Police have questioned me mainly who lowered it not how low and they seem to think its ok its fine for me
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Don't stick ultra lows in the back of it, then try to make it over a speed bump with someone in the back (even worse with a full tank of fuel)
    It doesn't work, you will scrape everything, tell everyone to get out so you can make it over the speedbump, them tell them to get back in. Would look funny too.
    Go superlows all round, and mabye get some lower profile tires.
    VP Exec,Gsx-R 750
    Mar 2005
    I have a Vp SS running 18 inch VY R8 Clubsport rims and I have not had a problem. My car is on Supers at the front and Ultras at the rear. If I go relatively slow over speed bumps I have no concerns.
    Mine is also IRS, and I had a camber kit in put in when I had it lowered. I do not, nor have I ever, had scraping issues with a full fuel tank, or a load of passengers in the back.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Try putting some kind of bodykit on your car and see how many problems you have after that
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by Cobez View Post
    It has the SS bodykit.
    VP V6 Executive
    Jul 2005
    ey guys thanks for the input. i been in sydney the last 2 weeks so i havent realy had time to get on this. Yes my car has got IRS... ill get some more info about the width but i think the info i have is good enough...
    thanks guys
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by stockies View Post
    hahaha i had to do that once but my car wasnt lowered my exhaust just hung down too low and it was a huge kerb at the airport they put a bit of sand so u could drive up but not enough :S
    13.3 1/4 exhaust only untuned!
  1. FE2 suspension
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2011, 09:09 AM
  2. Some questions about suspension, K&N pods and CAI..
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 06:35 AM
  3. a few questions about VS series 2 (suspension and gearbox issues)
    By heatersarecool in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 11:57 PM
