Hi,
I got a vx dash cluster with digital panel givin' to me and i am just wondering if i could use this in a VN ...
(edit: The VN is a Commodore S 1990)
I know that they might not be the same size but will it connect ok and work
Thanks in advance,
Sonny
To put it simply, no, the VX dash works from the BCM which gets info from the ECU from the VX's which is heaps different to the VN's.
To get it to work you would probably have to put an ecotec motor in with loom to utilise the later ECU and then wire in the later models body loom to utilize the BCM, and then modify your dash to fit the VX instrument cluster, pain in the ass.
