Results 1 to 5 of 5
Thread: Opening the TB 100%
    89 VN Exec, 94 VR SS
    Dec 2007
    Default Opening the TB 100%
    Hi, was wondering if anyone (greenfoam..) could tell me if my tb here is opened 100%?
    I posted on How TO but this is more busy.
    The pics arent great..
    first pic is the tb in general, second is turning to open the tb, third is the tb open it appears to open right to the middle, also the 'stopper' on it hasnt been touched.
    Is there any harm or gain to grind it back a bit if its already 100%?
    thanks
    ok after accelerating to full on the pedal the butterfly opens 100% while exactly touching the stopper but now my question is, when doing so the cables, esp the right cable seems very loose and turns abit, is this normal?
    Attached Thumbnails Attached Thumbnails Opening the TB 100%-bens-vn-007.jpg   Opening the TB 100%-bens-vn-009.jpg   Opening the TB 100%-bens-vn-011.jpg
    VP exe
    Sep 2007
    If its works, car idles fine changes gear fine then don't touch or grind it.
    maybe adjust the throttle cable if need be.
    personally i got a lot of greif from playin with the TB.
    If its sweet then there is sfa you can do but clean it.
    unless you go a 70mm TB or get it bored out os somthing, i dont know a lot about that.
    cheers
    Gone Fishing...
    VP Executive R-spec
    Jan 2005
    If it's opening straight allready then there's no need to make it open straight :P
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    boring a bigger throttle body and to make the butterfly takes no more than an hour and the resposive is massive
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Zuicider View Post
    if you've got a lathe and can make/buy a bigger butterfly to suit. most people dont
  1. Opening VS bonnet - help
    By ernist_pagnito in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 08:59 PM
  2. opening locked glovebox
    By gopher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2006, 07:44 AM
  3. Pornoclips (careful when opening).
    By kowan in forum Jokes/Humour
    Last Post: 17-11-2006, 09:34 PM
  4. petrol cap cover opening / bonnet opening
    By Rev_neil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2005, 02:13 PM
