Results 1 to 18 of 18
Thread: Wheel nut thread snapped off
    VY SS
    May 2005
    SA
    Exclamation Wheel nut thread snapped off
    Heard some ticking, which turned into shiuddering coming from the front left wheel over the last week. Didn't bother looking into it nor had i got the chance to really look at it.
    Finished up work today, comin home and it became real bad, so i pulled over straight away and a wheel nut thread had snapped clean off. Checked all the other nuts, and they were way too loose.
    This has me stumped, the last time i had changed wheels (2 months ago) they were definatley tight and the wheel definatley flush against the rotor and out of the blue, they've became loose? Anyone have any ideas what may have happened?
    Cheers, Gaz
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you rooted someone elses girlfriend?
    Sounds like someone has undone them.
    Visit my Facebook page
    VP Exec
    Jun 2005
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Cheap6 View Post
    Perhaps an interrupted theft attempt (of the wheels)?
    Good theory.
    VP exe
    Sep 2007
    lucky mate you could have been driving then watching your wheel overtake you
    Gone Fishing...
    mischa's Avatar
    mischa is online now <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Just_a_stocker View Post
    lol, not a good sign... just see you driving along "what the hell is that?" 'thud' car drops!
    i say its looks most likly like a stealing atempt.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VN SPAK
    Jan 2008
    did u have the right wheel nuts for the rim, ie if u have chasers then u should
    have a taperd wheel nut.
    if u dont know what rims do u have.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I've had that happen. Saw My left rear wheel flying through the air (looking out my passenger side window)
    My biggest problem was finding a way to jack the car up without a wheel on it.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Always make sure that before putting wheels onto studs that all studs are clean (NO OIL or GREASE) and dry. Do up nuts to specified torque using a torque wrench. Anything else is usually a recipe for disaster such as wheel nuts working loose because they have been overtightened and stretched the lugs.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Because all tyre shops use a torque wrench to torque the nuts up to the correct spec. Oh, and we live in Australia, they are called studs, not lugs.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Benboy View Post
    I do all my own up myself with a wheel brace. The time i had my wheel come off was my own fault, as i had spacers on, and the nuts weren't on enough turns.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    No, they get lazy and use a air gun, and thread your nuts so you can't get them off with a wheel brace, when you have a flat.
    cheers sexy
    VP Exec
    Jun 2005
    Quote Originally Posted by STEALTHY View Post
    And they do the first one up with the wheel hanging on the studs, rather than do one nut up finger tight first. (It avoids lifting the wheel up into position using the taper which otherwise eventually destroys the wheel and the nut).
    I don't like oil or grease on wheel studs/bolts either. Some WD-40 or similar if you must, because it's not that great as a lubricant.
    VN SPAK
    Jan 2008
    u should put a little little bit of grease or better some nickle anti siaze.
    if the studs are dry there is more of a chance of u strippin the nut or
    stud. they should never be dry. also the grease stopes the threads from rusting if the wheels are on for a long time.
    and i am a tyre fitter by trade
    VN SPAK
    Jan 2008
    and the main reason y shops tourqe wheel nut is so u can do it by urself on the side of the road
    when u get a flat.
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    I usually do all 5 up by hand first, and just tighten with the brace.
    cheers sexy
  16. #16
    VN SPAK
    Jan 2008
    [QUOTE=Cheap6;702724]And they do the first one up with the wheel hanging on the studs, rather than do one nut up finger tight first. (It avoids lifting the wheel up into position using the taper which otherwise eventually destroys the wheel and the nut).
    If they do that, they r not a very good tyre fitter
  17. #17
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by vnskidder View Post
    Most places do, and aren't!
    cheers sexy
  18. #18
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    How would u go about lengthening stud threads? and does some1 know wat the standard size of a stud thread is?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  1. Help! Key Snapped Off!
    By PsYko in forum General Discussion
    Last Post: 28-03-2007, 01:55 PM
  2. Snapped!
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2006, 10:19 PM
  3. Fly wheel/starter thread issue
    Last Post: 16-08-2006, 05:34 PM
  4. No Camo VE snapped
    By minux in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-06-2006, 03:25 PM
  5. VE snapped!!!!
    By The1985divo in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-05-2006, 09:27 PM
