Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Dented Engine Oil Sump. Help!!
    VN S2 Berlina Wagon
    Apr 2004
    Default Dented Engine Oil Sump. Help!!
    I accidently jacked my car from under the sump(brain explosion) and it has dented in about 30mm in the centre...gradually less mm further to the sides. I have not attempted to start the engine but I can turn the motor over manually. (I dont think the crankshaft is rubbing). I'm guessing the oil pickup will be pushed up too? Do you think it will be damaged? and is there a way of pulling the sump back out without removing it. eg. some type of suction or magnet device? Would it be drivable in it's current state?
    Can someone please help my stupidity...It's fairly urgent.
    HoneyJumble is offline Banned
    VL, VN SS
    Jan 2008
    QLD
    vn calais, vs clubsport #137
    Jun 2005
    not without breaking your gasket anyway... put a new sump and gasket on, and perhaps a new pickup depnds if youve hit it or not..
    lesson learnt
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    My brothers has a dent in it, has had one for ages, the supercheap trolley jack let go and it caught it on the sump. Been like it for months, no problems, but i guess it depends on the severity of the dent, and if you can afford to take the risk.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VN SPAK
    Jan 2008
    it would depend if the oil pick up is block or partly covered, then that couls be bad.
    where abouts in brissy do u live.
    i work a Qld motor recyclers and i might have 1
    under line might,
    VN S2 Berlina Wagon
    Apr 2004
    I just measured the dent. The worst section is 14mm in from normal and there are no sharp folds/edges etc...not too bad I suppose. I started the engine and there are no unusual noises and the oil pressure light does not come on. I think I'm going to leave it. When I was turning the motor over manually I noticed the crankshaft pulley bolt is loose. What is the easiest/best way of tightening it. For now I just put the belt back on and held the p/s pulley while tightening it.
    VN SPAK
    Jan 2008
    vp executive
    Nov 2007
    lakes entrance VIC
    this happened to my fuel take the jack slipped and it pushed up a bit of the tank its fairly flat tho fixable or newbie?
    [SIGPIC][/SIGPIC]
    Screw the icecream...
    Who wants a moustache ride?
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by lazza44 View Post
    just start it up see if there is any rattles or thuds if not all is good as the sump when you take it off and take a look, is pretty well much double skinned,they are made pretty well to prevent crank hitting sump.
    have you access to any oxy/acetelene gear and a mig welder ? weld a couple of washers to the affected area..then heat up the area(not to hot-just enough to be able to pull dent out,you will know when using the slide hammer if it's hot enough or not) hook the end of a bent 2-3 inch nail which can be screwed into end of slide hammer into the washers and gently pull out (hence sliding effect of slide hammer )
    PS...things to do and be wary of....1)disconnect ECU completely,not just from the battery.
    2)depressurise and drain remainig fuel out of line from bulkhead to injectors.
    3)shield the fuel lines if your not comfortable doing this if you think that fuel lines are to close
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    nothin to worry about m8, mine is also dented everywhere pretty much, gets constantly hit goin ova bumps hasnt caused any problems so, its all good lol
    VN calais 91
    Aug 2005
    well.....this brings back memories....
    i jacked up on the sump too, but because i overshot the frame without realising it
    put a dent in it...no biggie
    then i went for a drive at night down a 'shortcut' in an alleyway....front wheels droppped into a long ditch, manhole cover sticking up in the middle, did this to the sump
    the worse part was being stranded at night, and then having to get the sump off WHILE NOT WANTING TO REMOVE THE SUBFRAME!!!
    so lesson - TAKE CARE OF YOUR SUMP!!! AVOID ALLEYS!
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    I would suggest replacement of the sump and gaskets and also replace the oil pick up,you might have also fractured the oil pick up pipe near where it is bolted to the bottom of the block.If left and is fractured over a short time maybe a couple of months you could say goodbye to your engine,because as the oil gets hotter the oil thins and then your oil pressure will considerably be lower than specifications due to the fracture in the oil pick up.Very common problem on a E series falcons.
    88 VN 5spd 3.8
    Apr 2007
    Corio,Victoria (Geehole)
    oh damn i did the same thing when i did my engine mounts now my sump looks like it sucking in its gut..and im gettin the knocking at start up for a min or so plus the oil light at idle...so is that a new sump for me or can i take off and whack it out???
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
    The VN calais i bought, was stolen but recovered, and the sump is all dented and not pretty, but she runs fine, without noises etc for a S1 VN 6
  15. #15
    88 VN 5spd 3.8
    Apr 2007
    i had the lifter noise already but the loud knocking only started after i did my mounts
  16. #16
    Jun 2005
    Quote Originally Posted by the executive View Post
    id get to changing your sump asap before that knock is constant or your motor just stops
    check out your pickup aswell to make sure you have damaged that also.
  17. #17
    88 VN 5spd 3.8
    Apr 2007
  18. #18
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
  19. #19
    88 VN 5spd 3.8
    Apr 2007
  20. #20
    88 VN 5spd 3.8
    Apr 2007
    well i got it checked out and the mech said the sump isnt to bad and should be causing problems. so i changed oil gone from castrol gtx2 20/50 to penrite hpr30..
    but still gettin that bottom end knockin is motor stuffed???
  21. #21
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Should be using HPR15 not 30, according to Penrite themselves, we have 15 in our VN and it runs perfect, not any foreign noises.
    Penrite Recommendations
  22. #22
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i have hpr 30 in my vn so does me parents vn and me sisters vp and mates vs and haven't hap a prob with it...neither know they recommend hpr 15. In fact the guy at super cheap said that they (penrite people) recommend hpr 15 but he said that hpr 30 is the stuff every vn-vs owner going in there, is putting in there car...a little thicker but these engines are getting on in age and need it...plus i don't think it would cause the engine to knock...i think there is some bearing damage or the oil pick up is clogged
  23. #23
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by jas98 View Post
    Yeah, I agree, shouldnt be causing a knock, though could cause a tick at the most.
  24. #24
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    So long as your oil light isnt coming on(low oil pressue) and there isnt any significant leaks anywhere you should be fine...
    Mine has a massive dent in it too... i think that it is a very common thing with the 'ol V6.
    aZk.
  25. #25
    VN S2 Berlina Wagon
    Apr 2004
    mine was actually a 20mm not a 30mm dent as originally stated. I have not fixed it and its been over 4 months so i think I'm in the clear. If your a good welder you could try welding a nut on and pulling it out with a large bolt...
  1. removing sump without taking out the engine - 83 VH
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2007, 11:50 AM
  2. FS: VS V8 engine mounts, 304 sump, master cyl and ABS compressor - Brisbane
    By Whitey in forum Parts And Other Items For Sale
    Last Post: 11-09-2007, 09:11 PM
  3. chrome rocket cover, sump and side engine plates
    By frankyj54 in forum General
    Last Post: 18-04-2006, 01:36 PM
  4. WTB VP Engine Sump
    By Madhouse_Dave in forum Swap / Wanted to Buy / Trade
    Last Post: 13-12-2005, 10:18 PM
  5. Different Engine Sump for Ecotec.
    By droidt in forum V6 Development And Modification
    Last Post: 01-10-2005, 07:19 PM
