just bought a vp cheapie everything is great but the air con not working. Compressor is not kicking in. thought it might have been just low in gas & pressure sensor not kicking in compressor. did a retrofit to r134a yesterday and the a/c still not working. checked power at the single wire under the coil pack that gos down to the compressor clutch and has no voltage. Checked fuse 9 and 12v there. any suggestions? anyone have a wiring diagram available so i can check a few things out??
i would assume that the fan is working inside the vehicle,does the engine fan come on, the next thing to do is check both sides of the low pressure switch on the reciever drier,next to look at is the ac switch in the dash,make sure it has a power feed and that it switches power through,after that the only other part is the thermostat but this is a bit hard to get at coz its right at the back of the airbox.I'm assuming its not climate control
Phillip![]()
