Results 1 to 6 of 6
Thread: Its got me stuffed??
    vp executive
    Feb 2008
    Default Its got me stuffed??
    Howdy all,
    I have a 1992 vp executive auto which is giving me a bit of grief. It all started when the crankangle sensor went. I replaced it and also put on a new harmonic balancer and it fixed the problem. I thought all was well but then on my way home one day it started to misfire. The misfiring quickly becomes so bad that the engine shudders and the belt tensioner starts to snap about, and then if i put the engine under any load it trys to and eventually stalls. If i try to start it again while its hot it doesnt sound good, almost like the timing is out???
    If I let the engine cool it will start no worrys and run for another 15-20 mins then do it again. I can almost feel it coming on, again it feels like the timing is slightly out.
    I borrowed some coil packs off my mates car and the same thing happened, 15-20 mins and it happens again, i put new leads on today and Im still having the same problem.
    At no stage has the engine light come on since Ive replaced the crank angle sensor.
    Today I noticed that if you use the gears and you are extremely gentle on the gas you can limp it home, i did notice however the exhaust was stupidly hot even the tail pipe was roasting.
    Any help would be greatly appreciated.....
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by Rookie 4.6 View Post
    Howdy all,
    was it a new crank angle sensor?
    vp executive
    Feb 2008
    No I got it secondhand, it will start fine any time up until it starts playing up??
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    vp executive
    Feb 2008
    I got another one here Ill chuck it on and see what happens!
    Thanks Guys, this is a great forum!!
    VN Executive S1
    Jan 2008
    Seaton S.A.
    Default might be coil pack
    might want to look at your coil pack too dude my vn did that too when it started to go
  1. Ever been stuffed around over the net?
    By Kikki in forum The Pub
    Last Post: 10-01-2008, 09:09 PM
  2. is my sub stuffed
    By lieos in forum Car Audio
    Last Post: 04-09-2006, 06:51 PM
  3. Stuffed Again!!!
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2005, 08:57 AM
  4. vl has stuffed up again
    By muffman001 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2005, 09:47 AM
  5. Stuffed LSD?
    By GrpA Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 02:43 PM
