the other day i took out my injector's and fuel rail i put them back in yesterday and front driver's side injector sprayed fuel every where i thought the o ring mustve unseated itself so today i took em out again and checked all the o ring's made sure the injector's where tight and put them back in well same thing happened but the pressure wasnt as high as yesterday
o by the way its coming from between the fuel rail and injector not the manifold its got me stumped any ideas?
[SIGPIC][/SIGPIC]
Screw the icecream...
Who wants a moustache ride?
either the injector isnt plugged into the rail good or the injectors o ring is no good, only two options
yeah ive just checked it again and same thing the injector's are as tight as possible (still wobly) the o rings look ok and i found that another injector the tip on the bottom is cracked the lil plastic bit but it is still holding together and running fine
i thought i could have something to do with depressurising the fuel line's as i could only crank it over since i had no ecu in the car would it still hold that pressure until startup?
dam this suck's i wanna drive her with the tune!
[SIGPIC][/SIGPIC]
New O rings then. They may look ok, but if they have flattened out on the edge then they will leak.
new O's then would auto pro have them or be able to get them?
[SIGPIC][/SIGPIC]
They should be able to. Chances are they would have them in stock.
i had to buy a pack of 100 in my town, coudnt just get say 20...but that arnt that exy.
o rings are funny things, they'll work fine for years, even when they go a little hard, yet disturb em and they will be problematic. best to replace em all and forgo more trouble with leaking injectors later
Body by Holden, Soul by Brock
the Legend will live forever
is $100 a good price for reco injector's and will vr and vn ones fit vp?
i think its dam cheap comes with new O ring's might be worthwhile ey
[SIGPIC][/SIGPIC]
bump.... cmon guy's i need too know quick thank's
[SIGPIC][/SIGPIC]
