Results 1 to 10 of 10
Thread: camber on front wheels
    kitted vn
    Feb 2008
    Default camber on front wheels
    heya all
    my vn has king springs in it
    front inner tyres are worn real bad, pretty hectic in steering too
    how can i go about fixing this problem?
    --Many Thanks--
    www.unstableprojectz.tk
    VP exe
    Sep 2007
    sounds like they are running with a lot of positive camber.
    what other mods have you done to the runnin gear?
    Pm assuming you have the lower kings, then you would need the Nolathane Link pins and bushes.
    Honestly mate get it diagnosd at a tyre/shock place, its easy and the are ok.
    cheers
    Gone Fishing...
    kitted vn
    Feb 2008
    tell ya the truth, dunno just bought it haha
    will goto tyre joint for sure
    --Many Thanks--
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Running too much negative camber if it wearing the insides. It is a common problem once you lower a car. When you lower it, the lower control arm moves up, this also pushes the bottom of the strut out giving it negative camber and also a bit of extra toe out because the rack is behind the control arm.
    Get a wheel alignment done.
    Visit my Facebook page
    kitted vn
    Feb 2008
    VP exe
    Sep 2007
    Quote Originally Posted by Not_An_Abba_Fan View Post
    ahh well there ya go, I always thought the obvious, like if the camber was negative(bottom of the wheels closer than the top), it would wear the outside .
    Gone Fishing...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Depends on how you are looking at it. Negative camber is when the top of the wheel leans in, positive camber is when it leans out. Too much positive camber or too much toe in will wear the outsides, and too much negative camber or toe out will wear the insides.
    VP exe
    Sep 2007
    ahh ok , then I have my positive negative round the wrong way.
    Gone Fishing...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Thought so, after your second comment.
    VP exe
    Sep 2007
    Cheers mate
    Gone Fishing...
  1. wobbly front wheels
    By greenvs in forum General
    Last Post: 29-09-2007, 06:33 PM
  2. Noise in front wheels
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-08-2007, 09:57 PM
  3. Problems with castor/camber angles in front end while lowering vx?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 10:22 AM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  5. How do i replace front camber bush
    By hsv14u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2006, 03:46 PM
