Results 1 to 7 of 7
Thread: how do i disconnect my trans from my engine???
    VN SS 5.0
    Aug 2007
    Question how do i disconnect my trans from my engine???
    im trying to disconnect my transmission from my engine but those bolts are almost impossible to get to. i managed one at the bottom but have 5 left. is there a different method to this???
    cheers. any info asap wood be sweeeet
    car
    Jul 2006
    greensy, melb
    disconnect the diff and undo all the supports for the tranny and put a jack under the tranny so the tranny is lower and resting on the jack so you have more room to get your hands in
    "A life lived in fear is a life half lived"
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    What odyssey said, but I also used a heap of extension bars and laid them along the top of the box far enough back to get the ratchet to work. I think I needed to use a uni joint on one of them.
    Reaper
    VN SS 5.0
    Aug 2007
    i managed to disconnect the transmission i just undid the engine mount arm thingy under it and got the crane on the engine and moved it forward enough to reach and undo the bolts now i just got to undo my convertor inside and bang engines out soon
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Reaper
    Yep, this is what i do, especially for the top 2 bolts. A stiffer uni joint is good to stop it going the flop on you.
    Be prepared to get covered in gearbox oil!
    missus (in more ways than one)
    Sep 2005
    i just changed my auto,
    best way i found is take off extractors/pipes and all the intake up tioo the manifold, then you can reach em all either from under or over
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by CSL View Post
    V6 or V8? Access to bolts is significantly easier with the V6
    Reaper
  1. Engine/trans weight
    By immortality in forum General
    Last Post: 09-01-2008, 01:58 PM
  2. VS engine and trans into a VR
    By Nicky t in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 02:04 PM
  3. 202 efi engine and trans wat are they worth
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-03-2006, 08:11 PM
  4. engine/trans. noise?
    By SLY-380 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-03-2006, 03:45 PM
