+ Reply to Thread
Results 1 to 8 of 8
Thread: help needed identifying an engine based on the engine number
    Feb 2008
    Default help needed identifying an engine based on the engine number
    hi all.
    i have a toyota hilux 4x2 that has a holden V6 in it.
    it's a non ecotec motor, and i was told that it's from a VP, but as im about to embark on a rebuild,
    ill need to know for sure where it's from, as it would affect part #'s ?
    the engine # is VH1091XXX (last three digits left out for security reasons)
    if anyone can help, ill be really greatful.
    thanks in advance.
    Jason
    VP exe
    Sep 2007
    If it is from a VP it will be a SERIES II v6 Buick engine.
    Telltale signs are thermostat at the front and aluminium fuel rails.
    sorry mate cant help with the numbers but one phone call to local Holden genuine parts dealer and I bet they could sort it very quicky.
    Gone Fishing...
    Feb 2008
    thanks.
    here's a pic of the engine bay.
    from what you say, it does indeed look like a series 2 buick...
    ill double check with holden 1st though....
    thanks again.
    Jason
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by V6_Lux View Post
    hi all.
    thanks in advance.
    Jason
    The engine numbers for the VN started at VH100000, (or VH1001000) so you should have a motor in the first 91,000 made. I peg you engine number at around the Oct 89 manufacture date (put into cars on the assembly line)
    Having said that the engine does look like a SII with the thermo housing at the front. Could be a VN series 1.5 too.
    and 3 Dangerous non ABS VN's
    Feb 2008
    thanks.
    i had read somewhere that some of the later VN's had the series 2 motor in them.
    jason
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power Tom_1569 Senator Tom_1569 Senator Tom_1569 Senator
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Its a VN series 1, have a look at the coil pack.
    And yes later VN had a series 2 engine.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    88GreenVN's Avatar
    Jun 2006
    21/07/1989 L360544 1990 ENGINE E/N VH1065705
    This was the Holden SII official date for the 90 engine. Just had to look at my spread sheet a bit more.
    Feb 2008
    the coil pack has bee replaced for a series 2 one.
    i had to replace the original one, so i could get the tacho adaptor to work
    correctly.
    something about the early coil packs only having a 5 volt feed on the tach wire, and the later ones having 12 volts ?
    that's what the manufacturer of the tacho adaptor said anyway.
    as soon as i swaped the coil pack over, the tacho started working correctly.
    jason
+ Reply to Thread
  1. Engine Number - Where Is It!
    By Waussie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 05:38 PM
  2. VX engine number
    By Hoppy in forum V6 Development And Modification
    Last Post: 26-12-2006, 01:46 PM
  3. Where is the engine number?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2006, 10:18 PM
  4. Identifying VN V8 engine parts
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2006, 05:34 PM
  5. 308 engine number
    By paulk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 09:55 PM
