Results 1 to 3 of 3
Thread: Urgent help needed leaking fuel from area near tank(hoses)
    VN Berlina 3.8
    May 2005
    Default Urgent help needed leaking fuel from area near tank(hoses)
    hi all i need some quik information on a leak that i have which is coming from an unknown pipe. there is some sort of box that is attached to the fuel tank (near the top) where the fuel is eneterd from that has 4 outlets and 4 hoses coming from it. in my situation all the hoses have snapped (they all appear old) and there is fuel leaking out of one of them but because there is so many broken lines im not sure where they all go
    any info would help there is nutting in the manual
    First pic is the uknown box
    Second pic. the hose my hand is touching is the leaking hose and it dissapera on thop of the fuel tank somwhere. the two hoses that are in the red box i belive are ment to attach together cause the breaks line up
    Attached Thumbnails Attached Thumbnails Urgent help needed leaking fuel from area near tank(hoses)-pic1.jpg   Urgent help needed leaking fuel from area near tank(hoses)-pic2.jpg
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Those snapped hoses are called breather hoses, its to let fumes out of the tank. You shoudnt be leaking from them hoses, does it only leak when you fill it to the top? Have a look at this thread and you can see where the hoses go.
    http://forums.justcommodores.com.au/681780-post118.html
    http://forums.justcommodores.com.au/681213-post112.html
    VN Wagon
    Feb 2005
    The breather hoses and other parts of the fuel system age and break. You will probably find those pipes plus where they go (the other end) will have perished as well.
    Check out this post;
    Strong Petrol smell in my Vn
  1. WTB: URGENT Fuel tank
    By SSbeast in forum Swap / Wanted to Buy / Trade
    Last Post: 06-12-2007, 11:23 PM
  2. Leaking Fuel Tank.
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2007, 12:07 PM
  3. Help!! Petrol leaking from around sender unit in fuel tank
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2007, 08:44 PM
  4. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
  5. Fuel Tank pipes, hoses...
    By Knud in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 10:32 PM
