Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: Rattle in motor
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default Rattle in motor
    There is a rattle in my motor when under load or if its in neutral and i rev it to about 1500-2000rpm it rattles too. if i rev it anymore the noise seems to go away or maybe its just the motor is too loud so it overpowers the rattling noise. What could it be? Its annoying me. cheers
    Australia. Love it or leave it
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    VN SPAK
    Jan 2008
    does it lose oil pressure if it does its a big end, but i think it would be a cam bearing
    they r common if u flog ur car
    Jan 2008
    qld
    no it wont loose pressure alot of the time big bearings are from driving in and out of the garage and when the bearing starves for oil
    Apr 2006
    canberra
    Doesnt loose oil pressure or anything. Still runs fine aswell.
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Apr 2006
    canberra
    Na have never taken engine apart or tranny off or anything. i tried recording the noise but didnt turn out very well at all. sorta sounds like its coming from top of engine somewhere but not 100% sure.
    Boonz's Avatar
    Jul 2005
    oh might be your balance shaft then??? have heard a few of them become noisy over time
    VN SPAK
    Jan 2008
    Apr 2006
    canberra
    Whats the balance shaft? na does it hot or cold. Has made the sound for quite some time now, but have noticed it getting bit worse. mainly when its idling and i tap the accelerator a bit i can hear the rattle pretty clearly. While driving i mainly hear it when motor in underload like when im going up a steep hill or if i floor it in wrong gear. hard to explain really. And pretty sure its not pinging from poor fuel because i have tried every type of fuel possible
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Prob a few things that come to mind pretty quickly altho they have all been said
    1. Big end bearings
    2. Flywheel/Flexplate (happened to me a few weeks ago the flywhell bolts came loose)
    3. Harmonic Balancer could be worth looking at
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    Boonz's Avatar
    Jul 2005
    the balance shaft opposes the camshaft to help stop vibrations... runs on 2 bearings and doesnt really need to be there
    Apr 2006
    canberra
    Just went out and had another listen and to me its coming from top of engine. definly doesnt sound like its coming from front of engine so that rules out Harmonic Balancer. If it was big end bearings or balance shaft bearing, how long will it take for them to go completely. And what happens when they do? It has made the sound for like 2 years now, just gotten worse. So has done it to an extent for about 25 to 30000 kms.
    Boonz's Avatar
    Jul 2005
    well the balance shaft is driven by a gear that runs off the camshaft.... so depends what wants to break first haha.... more than likely stall the motor or snap the timing chain
  15. #15
    Apr 2006
    canberra
    But would it take the bearings over 30000kms to break? the car still runs fine thats the thing that has me stumped. Just has a bad rattle somewhere.
  16. #16
    Boonz's Avatar
    Jul 2005
    its a roller bearing so if the oil is crappy or insufficiant it can wear..... make it spin as fast as the camshaft is at high revs and it prolly wont like it after 300,000 k's.
    not saying its actually the balance shaft that broken but it is a definate possibilty
  17. #17
    Apr 2006
    canberra
    Hmmm hard to fix? and is there a way i can find out for sure what it is without taking it to a mechanic? short on cash at moment. I will prob just drive motor to ground then buy a new motor. might be easier.
  18. #18
    VP SS
    Jan 2008
    Hiding in WA somewhere
    check the harmonic balancer my made the same noises i almost pulled my motor apart bto find trhe noise unitl we finally saw it moving in/out in like a flexing motion replaced that problem fixed
  19. #19
    VN SPAK
    Jan 2008
    Quote Originally Posted by Peanuts Inc. View Post
    tha balance shaft has to be ther unless u have had the motor fully balanced.
    i have seen a v6 that has throw a rod because it didnt have a balane shaft.
  20. #20
    Black VN MANUAL
    Feb 2007
    Top of Vic
  21. #21
    VN S1
    Jan 2008
    I had a bad rattle 2 weeks ago or so, sounded like a piston had exploded and a conrod was slappin the cylinder ended up being 2 things cam chain adjustment and harmonic balancer. Hopefully itl be the same with yours, i was dreading having to buy a new engine and swappin.
  22. #22
    Apr 2006
    canberra
    Is there anything under the rocker covers that could rattle? Sorta sounds like its coming from there. also on way home thisavo i was driving through a massive storm and had my wipers on full speed and the left one snapped off haha. Never seen that happen before. how much is a new wiper? or would it be a lot cheaper just to go to wreckers?
  23. #23
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Does the rattle go with engine revs? take off a rocker and check the rocker bolts see if the rockers move abit it could make a noise with revs i tightend mine down cause they get loose cause from over reving maybe
    ~ VN POWER ~ Click the scales
  24. #24
    fishman's Avatar
    fishman is offline fishman
    VN Executive Wagon S2runningVP motor on dual fuel
    Nov 2006
    east coast tasmania
    yeah g;day cool commodore i reckon it could be your flexplate
    does it get worse in reverse what can you hear if you put big screwdriver on top of flywheel housingand listen thru handle
    a cracked flexplate will make a clicking sound
    it will decrease when engine warms up
  25. #25
    Apr 2006
    canberra
    Quote Originally Posted by Bz Kn33z View Post
    Na doesnt really go with engine revs.
    Quote Originally Posted by fishman View Post
    It doesnt decrease when engine warms up. If anything it increases. And it doesnt get worse in reverse. Havnt realy noticed it doing it in reverse at all because its not under load and no revs.
  1. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  2. I have a rattle too :(
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2006, 11:22 PM
  3. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  4. vs rattle
    By crainy in forum Car Audio
    Last Post: 20-06-2005, 12:09 PM
  5. VR Fan Rattle
    By ashley_salta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2004, 12:10 AM
