Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: V8 & V6 strength differences?
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default V8 & V6 strength differences?
    Any difference in strength between v6 and v8 diffs?
    VP 5L Calais
    Mar 2007
    S.A
    Feb 2007
    WA Perth, Joondalup
    What if I got a diff shop to shotpeen the V6 gears and would it cost much?
    VP Executive R-spec
    Jan 2005
    Yep they are shotpeened but it could be debatable if they make any difference. You don't see anyone breaking the gears in any sane car anyway. I'm running NA VL gears in mine and they don't break
    VP 5L Calais
    Mar 2007
    S.A
    i doubt that is and option, shotpeening (someone correct me if i'm wrong) is when the gears are pounded with heaps of ball bearings at high speed tocompress the metal and make it stronger and i presume it is done before the gears are machined, so i don't think you can get 6 cyl ones done, but chuck it in anyway it might last.
    Feb 2007
    WA Perth, Joondalup
    Ok, cheers, I just thought there was a large difference between them but thats cool.
    VP Executive R-spec
    Jan 2005
    Nearly every fast V8 is running gears from some low power car with big ratios and they aren't shotpeened. Plenty of them running 12 second 1/4s or better on those gears so I don't think you will break it
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    Quote Originally Posted by greenfoam View Post
    really wouldnt call 12 seconds fast anymore anyone with a gen 3 and few bolt ons can do that now lol
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    My mate in his stock auto v6 with simply a spooled diff managed to blow the gear teeth through the housing..... how ever he did snap two axles (wich obviusly were replaced) before hand. saying that the lash couldnt have been to crash hot after the first couple of axles
    Dont take it that makes them weak thow cause this diff took a beating and im very suprised that he didnt blow other things first.
    im not admiring your car im looking in disgust
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by VLDavo View Post
    12 seconds is certainly fast for a 5 litre or a V6 which run these diffs, the gen 3's run the 8 inch gears. 95% of VLT's don't make low 12's either no matter how fast people think they are. I've see a 11 second torana with a VN diff break several axels and never hurt the 4.11 gears in it
    HDT_aero, A friend of mine broke the gear in his VQ but he ran out of oil so it doesnt count , I'm sure you could break on with a big single spinner burnout until the spider gears weld their shafts and then snap off and THEN break the main gears, that happens. But that not really the fault of the main gears.
    VP 5L Calais
    Mar 2007
    S.A
    that brings me to another point, Are the spider gears and side gears shotpeened too in V8's
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    And they do it down Auburn St at 5pm hey Davo!
    VN SS 5.0
    Aug 2007
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by V85000i View Post
    I've read on the other forum that they are yes.
  15. #15
    missus (in more ways than one)
    Sep 2005
    quick quesiton, i have a "high performance" diff so the tag says, and with the age old jack it up and spin the wheels lsd test it passes with flying colors, but is it really an LSD cause they released diff with "high performance LSD" on the tag, it does LS but i want to know so when i get the gears installed i'll ask em to shim up the lsd and make it tight again
  16. #16
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    shot peening is fasinating to watch.
    simply the metal is heated to around 900* and only one ball bearing is fired at it,
    it is easy to tell if it fail to temper or not,bye sight and sound.
    a ping is heard like a crystal glass and a shockwave is visable to the naked eye,(sortof like seeing a bomb shockwave)
    running from the center to the outer in a radius motion.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  17. #17
    VP Executive R-spec
    Jan 2005
    Are you sure about that? I thought thousands of balls were shot at the metal to forge the surface layer?
  18. #18
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by CSL View Post
    High performance tags are normally on live axle and the LSD diffs actually say LSD (i.e. the high performance LSD that you mentioned).
    But if it passed the test spinning the wheels i'd say its LSD.
  19. #19
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    for the diff's that's posable but for tempered saw blades 500mm dia
    only one does the job.
    Powered By Garrett
  20. #20
    VP 5L Calais
    Mar 2007
    S.A
    that's what i thought.
  21. #21
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Not so long ago 12 was insanely fast for anything with a legitimate rego sticker.
    Reaper
  22. #22
    Reaper's Avatar
    Aug 2004
    My understanding is similar. It is a stress relief process that removes internal molecular stresses caused by the machining and hardening processes involved in manufacturing the gear. It is ideal because it doesn't significantly soften the gear surfaces.
    Reaper
  23. #23
    Mar 2006
    Quote Originally Posted by tigervh View Post
    spot on lol
  24. #24
    Mar 2006
    Reaper
    lol yea but times change ... lol look at the xr6 turbo my mate got his tuned at nizpro runs 12s on just a few tweeks lol..
    and with bigger more powerful engines comming out year after year its easy to have a daily 12 second car
  25. #25
    VP Executive R-spec
    Jan 2005
    I don't see how the 12 second car that runs one of these diffs suddenly turned into ls1s and XR6Ts which don't even run them :0. The truth is hardly any 5 litres or VL turbos run 12's it might seem like all VL's run 10s but I've raced at least 5 VLT's in my VP and only lost to one and my VP's still a 14 second car:P
  1. differences in vn v6 and v8
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 02:28 PM
  2. VY SS and VZ SS differences
    By hothouse vy s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2006, 12:33 AM
  3. T5 Strength
    By VN_Luke in forum General
    Last Post: 08-06-2006, 04:22 PM
  4. vs/vr differences
    By sarj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2005, 12:32 AM
  5. Borg Warner M76 strength
    By matt08 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-06-2005, 11:38 PM
