Results 1 to 11 of 11
Thread: ALDL Cable help!!!
    GIMPY1's Avatar
    GIMPY1 is offline Bass Slappin Mag Designer
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Exclamation ALDL Cable help!!!
    hey,
    this arrived today Commodore VLWalkinshaw/VN/VP/VG/VQ ALDL Diagnostics Kit - eBay. (end time 26-Jan-08 01:25:21 AEDST)
    and i got all excited and jumped in my car, plugged it in, booted up the lappy and winaldl checked the settings and off i went..... NO DATA! all i had was a flickering check engine lamp. is there something wrong somewhere? if someone can help that would be muchly appreciated.
    Quote Originally Posted by elmaso View Post
    maybe the guys really wasted, like 24/7, you know how booze can some times lead to hookin in with some fugly chick, well thats probably what happened with him and the car.
    GIMP Mobile V2.0 - In Progress
    VP exe
    Sep 2007
    not sure but with these kind of things you have to tell your computer or th program which port you are using. i.e. com 1,com 2, com 3 ect.
    Gone Fishing...
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    did you have it connected directly to a serial port on the laptop or through a usb converter?
    Mike
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by gimpy21 View Post
    hey,
    Hi there,
    Download EFILive from here: EFILive: Digital Tools for Onboard Vehicle Electronics (They have a free version) and make sure you select your particular car under "Vehicle Make". Mine worked straight away. I am assuming your cable is made correctly.
    Reaper
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    might want to select the right ecu in winaldl unless you just get efilive.
    in winaldl,click configuration, then for ECM type, click the arrows til you find 1227808. and yeh, make sure its on the right comm port
    89 VN 5lt
    Mar 2005
    Busselton W/A
    I'm having same problems But I'm trying to run it through usb, Can it be run through usb? or do I have to connect it to the one on the back of the lappy?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    I run mine through usb to serial adapter no problems some usb adapters are reported to not work but most are the same circuit inside you need to know what comm port the adapter is running as and set winaldl to the right comm port.I presume you loaded the driver for the usb-serial cable
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Quote Originally Posted by delcowizzid View Post
    Yep I loaded the driver for the usb cable. How would I find out what comm port the adapter is running as?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    goto start, control panel,system ,click on hardware,goto device manager,go down to ports comm/lpt you find it there.and if you plug it in a different usb port it will get assigned another comm number for each usb port
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Woohoo thanks delcowizzid I got it working now I just gotta work out what all these numbers mean
    в∞ѕтεכ √&
    Jul 2008
    NZ
    good to see you got it going the car will run a bit rough when its plugged in on a standard tune cause the timing gets cut back under 2000rpm and the blms wont be correct under 2000rpm so if you want to log cruise fuel ratio with the blm numbers and get a correct reading under 2000rpm youll need to get someone to burn you a tune with the diagnostic rpm turned down to 0000 then it will run sweet with the cable plugged in and will give you accurate blm numbers.you using winaldl or efilive I allways use winaldl myself.put up a winaldl log for us to have a look at.
  1. ALDL cable for VS
    By ntl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2008, 06:49 AM
  2. FS: ALDL Cable for VS V6
    By Avi8or in forum Parts And Other Items For Sale
    Last Post: 12-01-2008, 08:34 PM
  3. [BNE] VN ALDL Cable
    By ElDubya in forum Parts And Other Items For Sale
    Last Post: 25-04-2006, 07:21 PM
  4. WTB: ALDL Cable
    By pro_gmh in forum Swap / Wanted to Buy / Trade
    Last Post: 11-02-2006, 12:12 AM
  5. aldl cable
    By statement in forum Electrical Wiring / Questions
    Last Post: 22-11-2005, 10:50 AM
