Hi guys/girls,
Just wondering if i could get some opinions, I have a vk with the 3800 sieries 1 vn motor in it. I have just installed a HSV chip a crs super charger running 7 psi ( i also have a 5 psi pully) it has a 35hp NOS shot and methanol injection.
Ok so what i need to know is if the standard injectors would be enough or do i need to replace them.
replace for sure
hsv chip = nothing you will need remap with bigger injectors and boost
yeah ditch them and get a set of L67 injectors which r 36 pound
775 blue tops will be enough for that combo but you will need some work on the tune
ok thanks guys il look into getting some new injectors and get my old chip redone
ok i got another one for you all,
the charger came and works well but it has the t/b before the charger and its realy a pain in the butt were it is ok so my question is is it better to leave it there and just live with it or do i take it off and put it back were it should go? if i do that will i need a blow of vave? thanks in advance for your help
