how would i go about replacing my harmonic balancer?
my engine is out so the transmission cant stop the crankshaft from spinning.
i had a few ideas but im not too sure.
any help would be sweet.
put 2 bolts back in the crank shaft and use a bar to lever against
Or get a mate to hold a screw flat driver in the ring gear teeth on the flexplate against a dowel or fixed object around the bellhousing and use a socket and long bar on the bolt......the v8s dont have as much torque (190)on the centre bolt as the v6s (300) so you should get it without too much trouble
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
cheers yeh thats wot i was thinking of doing just jamming the crankshaft somehow from the bak against the flywheel or sumthing.
should go easy.
