Hi got a coil pack/dfi of a vp and i wanna swap it over for the one thats on my vn-s1, the mounting looks different !, what do i need besides the pack to swap over ?, thanks..............
you shouldn't need to change anything i got a vr series 2 coilpack on my vn series 1 and it was a straight swap no need to change anything the dfi plug is identicle the three bolts underneath fit straight into the holes on the bracket easy swap
hi , just hooked up the coil pack from the vp , well ill be, nothing ,turns over thats it ! , maybe put the leads wrong, are the vp leads in a different order ?. Anyhow replaced with vn gear ,sprayed contacts with crc ,tightened up the female side of plug and the car runs at least,not fantastic but at least it didnt cut out, last time i took out the plug and gave it a spray it lasted 10 days before it konked out ! , normaly get out of car give it a wiggle , and away you go !. Anyhow been running a bit crappy of late, seems to be missing especiely when hot it nearly stalls, on the open road no worries !, thats one reason i wanna put a different pack/dfi in, cas was done not long ago, made no diff, leads done aswell., thanks........
the vp s2 coil pack is the same as the vr coil pack it has the numbers for the leads on the topas well they are all on same side of the coil pack?? so I guess that the one you got is not working or something like that
Thanks for reply , i left the old setup bolted on and just put the plug then leads on the vp model one so the coil pack just rested there ,turned it over nothing,oh well back to the drawing board !, wreckers want 90$ for a vn-1 set up ,if its o'k' beats 288$ for a new one. by the way, just to make sure standing in front of the car , which is no1 cylinder, is it the front drivers side (facing the radiator) then left front number 2 then back over to the other side for no3 etc ?, thanks..
it sounds like a loose wiring/bad connection problem with the plug connection. get some contact cleaner and clean it properly. make sure it's dry before pluggin it in again
Body by Holden, Soul by Brock
the Legend will live forever
Use CRC CO CONTACT CLEANER, i use all the time when buidling and cleaning computers, dont use regular CRC.
Also im abit lost with what your problem is, but we just upgraded from series1, to a VR coil pack, trhe conversion is a straight swap using coil pack and DFI, we got the VR leads with ours aswell, set us back $150 from a reputable wrecker.
Thanks for all replies , finally put the vp setup on ,connected it properly and wammo , started o'k' runs without konking out, but ! , when it warms up still seems like its missing, but only at idle ! , open road runs fine, so now i have had the cas, plugs,coil pack,dfi replaced and cleaned out the throttle body, realy still no improvement at idle, so its got me buggered !, thanks anyhow guys...........
ok if your in adelaide I can tell you the cheapest wreckers around is semaphore wreckers I got two vr coil pack/dfi units from them for $75.00 each.
oh yeah did you clean iac valve on the tb I did mine the other day and it was really filthy but got it back to a bronzey colour now Idles better than it did before
Yer could be right on the tps !, when i first pull up o'k', then after a second or two idle drops down and car starts to run s!@#house sometimes is worse than others, and there seems to be a lag in takeoff like the throttle is slightly stuck!, but when its underway no probs normally , go figure ?, thanks.........
Ok sounds like TPS to me, sounds exactly likes my brothers VN which is about to get a new TPS put in.
The other thing is, the accelerator cable on series 1 is a pain for coming loose, you will see where it meets the engine, theirs a bracket and a bolt on each side, make sure their tight, tight as possible. Our likes to come loose and the bolt will just float around the cable, makes response and over all power a pain, but wont affect it at idle really.
