Results 1 to 25 of 25
Thread: tps
    vn vacationer auto v6 sedan
    Jan 2006
    Default tps
    Hi , can anybody provide me with a diagram/pic of where the tps on the throttle body is on my vn/v6 ?, thanks i dont want to make any mistakes !...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I can grab a picture, maybe a make a workguide on how to change it, depending on how long you can wait. I have to do this on my brothers VN, but he wont have the money for a while knowing him lol.
    Anyways if you follow the big air tube back to the TB, its just under that, its has some wires going to it. I had a quick look at what need to be done to change them, and it looks like it would be easiest to remove the air tube to get good access.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Jan 2006
    thanks, im trying to eliminate reasons for bad idle and this could be one .
    Jan 2006
    by the way whereis the idle solenoid and what does it do ? , thanks..........
    VN Executive S1
    Jan 2008
    Seaton S.A.
    ok on the throttle body you have two sensors the one at the back is for idle control the one under the throttle body is the tps to clean the idle control motor you need to remove the TB from the car you will need a torx 20 screwdriver or bit and heaps of rags aswell as throttle body/carby cleaner both sensors use the same torx bit. I cleaned mine the other day came up spotless cleaned the butterfly and the idleports real good but made a huge mess on my nice clean garage floor hence the rags.
    Jan 2006
    while im at it i might as well clean everything out , i thought the butterfly is called the air control valve , is it not ?, or is that something else?, thanks........
    VN Executive S1
    Jan 2008
    Seaton S.A.
    VN Executive S1
    Jan 2008
    Seaton S.A.
    ok you'll need to clean these out bear in mind I have only shown you the TB from the front and side there is also a idle control port at the back that needs to be cleaned out as well
    the Idle control does what its name implies it allows more airflow or restricts it to keep engine at a constant RPM
    VN Executive S1
    Jan 2008
    Seaton S.A.
    quick note these later pics are of a TB that hasn't been cleaned as it is just a spare needed it for the TPS lol
    Jan 2006
    Jan 2006
    Hi , just ripped of the throttle body , took out throttle posi sensor and idle control solenoid , as thought heaps of gunk and stuff in the passages especially the idle solenoid spring and plunger and its passages. What i was wondering was will the solenoid and tps from a vp fit ? , i can get it of my mates wreck, ide like to see if it makes a diff, also the throttle cable plate has a plastic housing containing the spring underneath it, my housing containing spring is in 2 bits with a part of the spring poking out sort of lop sided , could this have caused stiff accelerator action at first when pushed down ? , thanks..............
    '97 VS Commodore + '98 E36
    Apr 2005
    VN Executive S1
    Jan 2008
    Seaton S.A.
    yeah vn vp vr v6 and v8 just need to modify the v8 by puting the v6 throttle cable assembly on it
    VN Executive S1
    Jan 2008
    Seaton S.A.
    could do I think it sounds like something isn't right with yours and the tps and idle control will fit as mentioned above but the throttle body will too, easier just swap TB's
  15. #15
    Jan 2006
    Thanks guys , pilled t/b off and cleaned it all out, reassembeled , started her up same as before ,mates gonna bring spare idle valve solenoid over tonight , but in the meen time i drove the car up and down the road , rpm stayed at about 2500 !, lucky the brakes are o'k' !, i reckon i have stuffed up the tension spring under the accelerator plate any body got any info/pics on how its supposed to look like when its on properly !, the 2 prongs of the coil spring just poke out and dont touch nothing the way i done it, must be wrong, thanks........
  16. #16
    Jan 2006
    Just went over everything again , finally got return spring on properly and runs much better now , if anything idles to fast by 200/300 revs , hoefully ecu will reset idle over time !., thanks........
  17. #17
    YVR05L's Avatar
    YVR05L is offline I NEED BOOST!!!!!
    VR SII Manual 5.0 Ute
    Jan 2006
    Next Door
    Make sure you did the TB bolts up tight, or that the gasket didn't have any cracks in it, that would cause it to idle a little higher, due to air seeping into the motor, or you might just need to adjust the butterfly screw might have wound in a bit.
  18. #18
    Jan 2006
    yep ill check tomorrow , mate just dropped off complete intake/manifold , so i can juggle bits around to see what happens , actually was a cool night drove home car seemed to run not to bad !,maybe revs a little high,i reckon the gasket might have been split when i put the t/b back on, do u think it would make 300rpm diff ? , thanks........
  19. #19
    VN Executive S1
    Jan 2008
    Seaton S.A.
    if you got complete manifold assembly just take the throttle body off that one check if that gasket is any good and use it if it is also maybe think of using the other throttle body if you want
  20. #20
    89 VN Exec, 94 VR SS
    Dec 2007
    Quote Originally Posted by ab56452001 View Post
    I know its been said alot but its best to reset your cpu after you put it back together.
    1. remove fuse above battery for 5 mins
    2. discon battery for 10 secs
    then i think with both methods you need to rev to 3000? for 10 secs or so then put it in drive and hold the brake on for 30 secs and hopefully it will change to a better idle speed
  21. #21
    VP exe
    Sep 2007
    also remove the neg battery terminal before you touch anything.
    negligable,, yes but it can happen so its good practice
    you dont want to spike the puter
    Gone Fishing...
  22. #22
    VN Executive S1
    Jan 2008
    Seaton S.A.
    if you have air con and auto you need to run for 30 secs in neutral with air con off then 30 secs air con on in neutral then 30 secs in drive foot on brake air con off then 30 secs in drive air con on. if manual its just 30 secs air off 30 secs air on in neutral
  23. #23
    Jan 2006
    Hi , well thats about it ! , ive tried just about everything , reset idle, swap tps/dfi/coil pack/cas and idle solenoid !, cleaned it all up and at least it runs now , so i guess ill have to life with the idle around 200 -400 to fast !, thanks anyhow..............
  24. #24
    Dec 2007
    Someone had a problem with high idle. it turned out to be his tacho giving a higher reading than i think it actually was, maybe somehting to try if you have changed all that
  25. #25
    VN Executive S1
    Jan 2008
    Seaton S.A.
    lol take dash apart pull off the needle and set it 200 rpm less than it was lol
