Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Loud Ticking coming from engine
    Jul 2005
    Default Loud Ticking coming from engine
    Last night went on a cruze and on the way back to geelong my car started to tick, pulled over and it was really loud under throttle, my oil light did come on but only for a second and i checked it just before and its in the middle. I cant work out what its coming from but its really loud and doesnt sound healthy. Anyone have any ideas?
    VN Executive S1
    Jan 2008
    Seaton S.A.
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    My car makes a load ticking noise too, put it down to lifters... Its anoying but u get used to it!
    Jul 2005
    my mate said he had the same problem and it was a plate between the auto trans and the engine has cracked. Just checked again to see where it was coming from but its gets louder behind the engine or towards the back of it.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Is it sort of like a weird sound, not quite like a ticking / clicking sort of sound? And it sounds worse on cold idle?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Jul 2005
    its sounds the same on warm and cold idle, sounds like somethings loose i will take a video of it and put it up on youtube, only way i can really explain it since its really weird
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Hmm doesn't sound like mine. I think mine is an exhaust gasket making like this "clack clack clack" sound (stupid post i know, but that's the only way i can explain the noise LOL)
    Jul 2005
    Another thing is it also doesnt really do it if its idleing its as soon as you start the car its not as loud. The rev's drop down to where it should idle and it stops, rev it just a tad and then it starts and gets loud depending on how far you rev it. As soon as you stop reving it the ticking stops aswell. like highway driving does it through to about 80 then after that it doesnt tick.
    YouTube video = YouTube - Vn Loud ticking Problems
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    loose engine mounts?
    Loose exhaust manifolds knocking on the chassis? (my VB does this a little at slow idle and it sounds simular to that)
    that sounds like something is loose for sure...
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    NO CAR ATM.. -.-
    Jul 2006
    my friends vr had the same noise! its not really ticking its like a knocking sound... coz hes harmonic balancer was destroyed
    94 vr executive manual
    Jan 2008
    top up ypur oil to the full mark the noise should go awat thats what happened to mine and i thought the oil pump was shot top up the oil level first
    Jul 2005
    i will check after i get something to eat, i noticed that i need a new belt for the engine aswell since its starting to crack.
    VN Executive S1
    Jan 2008
    Seaton S.A.
    NO CAR ATM.. -.-
    Jul 2006
    yea all these things will make it sound like crap it could be the oil thing like they said.. the waterpump doesnt really make much noise mine was stuffed for 4months n i heard no difference... n no the belt doesnt make it sound either mine was cracked i put a new one on n it sounded the same.. yes do the oil thing
  15. #15
    Jul 2005
    i will have to change oil tomorrow since i hardly have any left and have to get new oil filter to change oil anyway. I have checked all things around the engine to see if they are knocking on anything and nothing is knocking. so it isnt anything like exhaust manifolds.
    I have a few steps now to see whats wrong with it.
    Step 1 - Change oil and oil filter
    Step 2 - Check harmonic balancer since i have been told that could also be the problem
    Step 3 - Check Lifters
  16. #16
    Jul 2005
    ok checked over everything again incase i missed something and i re-checked my oil level. It was half full before now its close to empty.
    I havnt started the car since i took the you tube video hours ago and i wiped the oil of the stick and put it back in like your meant to before you pull it out again and check it both times. No oil has leaked at all.
    I dont know if i have been leaking during the cruze or not. If not then would it be likly that i have damaged anything? Oil light only came on for 2 seconds when idling on the way back home apart from that the car was running really nice all night (probably its best in a while)
    I have pictures of the dint in the sump and the actual stick. My finger is where the line is for full and the black line is add.
    Attached Thumbnails Attached Thumbnails Loud Ticking coming from engine-img_0614.jpg   Loud Ticking coming from engine-img_0615.jpg   Loud Ticking coming from engine-img_0616.jpg
  17. #17
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    dam!! thats a pretty decent dint ya have...may have stuffed the oil pick up pipe which is baaaaddd...the oil light should not come on at idel or any time dureing driveing tha car only time it should come on is when the car is first started
    id say there is a fair bit of damage to the oil pick up pipe
  18. #18
    Jul 2005
    dints been there ever since i got the car and it ran fine after and before i got it but i might price a new sump and pickup
  19. #19
    missus (in more ways than one)
    Sep 2005
    2 things, harmonic balancer, check if the rubber is in tact, judging by the sound from the video it is the balancer, cause lifters and stuff wouldnt sound that clean, they would be muffled.
    or as someone mentinoed before could be your flywheel/driveplate.
    mine cracked and make a **** horrible sound, worse at idle thou
  20. #20
    Jul 2005
    a mate came round with some oil, put it in didnt do anything, its not the harmonic balancer so i might have to take it to a mechanic tomorrow if i cant work out whats wrong with it
  21. #21
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    [QUOTE=sp4nky;720152]dints been there ever since i got the car and it ran fine after and before i got it but i might price a new sump and pickup[/QUOT
    ah ok yeh would be a good idea as like i said its a pretty decent dint
  22. #22
    Jul 2005
    ok i went to a mechanic this morning. he listened to it for 2 minutes and said my crank bearings are shot.
  23. #23
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by sp4nky View Post
    ah yeh i was gonna say it sounded like bearings however i aint really experianced with that noise......hmm sounds expensive
  24. #24
    Jul 2005
    yeah im just going to buy a second hand engine to get myself around till i can take it off the road again and put a 5lt or 5.7lt in it. Ether way i need a new engine it aint worth repairing because the mechanic said it would have chewed away some of my block aswell.
  25. #25
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Farr those noises are loud. I have a noise for last few weeks, only hear it when im idling, in drive, if its in reverse, neutral etc no noise, only in drive, if i accelerate slighty it goes away. I cannot hear it from the front of the engine. THe moment i lift my foot off the break it stops knocking. Its like a buikd up knocking noise, when i stop and idle at lights, it builds up slightly then loud. On certain angles when i park its sometimes not there. Yesterday it changed slightly, it would knock slightly (same knocking noise) when i drive off for like 1 second a few taps then gone........pis&ing me off!
  1. loud knocking sound in engine bay **youtube link**
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 09:16 PM
  2. wierd ticking noise constantly coming from fuel rail?
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 09:55 PM
  3. loud ticking noise + no goes, valvetrain issue
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2007, 04:13 PM
  4. Ticking noise, apparently coming from catalytic converter?
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 02:10 PM
  5. Ticking Noise Coming somewhere from Engine
    By Dane in forum General Discussion
    Last Post: 04-09-2005, 05:52 PM
