Results 1 to 12 of 12
Thread: Help with cahnging power steering fluid.
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Default Help with cahnging power steering fluid.
    Probably a really stupid question, I know. But how do you change the power steering fluid? More specifically (and to make me sound not so stupid,) where do you drain the old fluid from? Is there a plug on the rack itself?
    Cheers,
    Sam
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    Well how i did mine when i replaced the pump was to leave off the return line and start the engine and pump the fluid through into a waste container,it does'nt take long to empty either,i kept doin it till i had clean fluid through the hose.
    Regards Phillip
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you will need a bucket and a few litres of dexron 111,
    -unclip the resivour and drain the old fluid,
    -undo the return hose off the resivour,
    -drop the return hose into the bucket,
    -block off the return hole in the resivour with your finger or bung etc, can also remove the resivour and stick a funnel in the hose
    -fill the funnel/resivour with fluid
    -have someone start the engine - and quickly keep up with the fluid topping up so the resivour or funnel doesn't run dry
    -when clean fluid comes out the return hose stop the engine put it all back together and top up fluid
    -start the engine again and turn the wheels lock to lock about 5 times, stop the engine and re-check the fluid
    clean it all up and your done
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    How often are you suppose to change power steering fluid?
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    there's no specific interval but if the fluids dirty ditch it i guess, maybe every 50 or 100,000km i guess if your picky,
    VN Wagon
    Feb 2005
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by TurboXS (Pete) View Post
    My VN automatically drains the power steering fluid every few months.
    thats what i was gonna say...why drain it when the car automaticly drains it for u from factory lol
    NO CAR ATM.. -.-
    Jul 2006
    lol this is very weird i not even once had to top up my powersteering fluid n its been over 1year..
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Thanks everyone. will do this on the weekend.
    I haven't had to top the fluid up, in over a year. But when I checked it the other day, it seems pretty bad!
    Cheers,
    Sam
    89 VN Exec, 94 VR SS
    Dec 2007
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    my pump has never leaked a drop.
    i use a similar method as above but i don't run the engine, if the pump runs dry your just going to damage it. i remove the return hose from reservoir and drain old fluid into suitable container. i then plug this hole in reservoir, put return hose into old 2.25ltr coke bottle, fill reservoir with clean fluid and turn steering wheel lock to lock (i do this when i have car jacked up), refill reservoir with clean fluid and repeat process until you have clean fluid coming out of return hose. but keep going until reservoir is empty, that way when you unplug the reservoir return it doesn't leak fluid everywhere until you refit the return line. make sure you fill reservoir befire starting car this method works well if you are working on the car by yourself.
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    well my pump and rak has been replaced by previous owner, so it dont leak a drop. however there would be only a small amout of cars with the original (factory) pumps/rack NOT leaking
  1. Power steering fluid leak - VP
    By LoZzA199 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 11:34 PM
  2. Power steering fluid
    By 14000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 05:41 PM
  3. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
  4. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
  5. Leaking Power Steering Fluid.
    By Lukie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2004, 05:40 AM
