i was wondering about the difference between v6 and v8 diffs does the tailshaft from a v8 bolt straight into the v6 diff?
the diffs are the same...V8 tailshafts have 100mm diameter center CV joints. good upgrade for a V6 making some power..... but apart form that i think they are the same lengths.
well im putting a v6 diff with a locker and 3.9 gears into my vn v8 cos i wanted to get rid of the worn out LSD and was wondering about that so yeh.
cheers
the diffs are identical and will bolt straight up. the driveshaft uses a flange arrangment to bolt to the diff, the flanges are the same for V6/V8.
never knew that about the universals. will need to check that next time i have a V8 laying about![]()
Body by Holden, Soul by Brock
the Legend will live forever
didnt think the v6 got 3.45
good luck finding a v8 3.45
Gone Fishing...
im not looking for stock gears or anything.
all im looking for is a single spinner so i can chuck a locker in and after market 3.9 ratio gears. i got it yesterday anyways picked it up for 80 buks
Does the above also apply for IRS ?
And does anyone know if its possible to find lockers for the IRS diffs?
I rang CMP in Perth (I work at a large retail parts store) and got laughed at basically. And told a Mig welder was the only option.
I refuse to weld the diff as I have seen the result of a weld breaking and locking the diff up at high speed. Nasty!
the IRS has the same center as the live axle setup. if it's a standard open diff you can fit a spool or if you wish a detriot locker or airlocker as you please. if it's already LSD you need to get yourself and open diff center to do the conversion.
