Results 1 to 14 of 14
Thread: Bumper Removal
    GIMPY1's Avatar
    GIMPY1 is offline Bass Slappin Mag Designer
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Default Bumper Removal
    Hey, this has probably been asked a million times before, did a search for the past 2 hours and still nothing. i need to get my bumpers off my VN sedan so they can be sprayed, problem is i dont know how! had a bit of an explore but the rear one defiantly has me stumped... any help would be appreciated!
    Quote Originally Posted by elmaso View Post
    maybe the guys really wasted, like 24/7, you know how booze can some times lead to hookin in with some fugly chick, well thats probably what happened with him and the car.
    GIMP Mobile V2.0 - In Progress
  2. Default
    it's easy. for the rear there are 2 nuts in the boot and then simply pull the bumper off. for the front you need to remove your headlights and grille to get to the bar where the bumper sits. once your headlights are out, put your head over the engine bay and look towards the bumper and you will see some bolts. there are 4 in total. once they are removed, the bumper pulls off forward. if you need more help i'll make pictures!
    Quote Originally Posted by zai View Post
    I am not sutpid
  3. Default
    yeah the rear is pretty straight forward but here i uploaded a photo of the front, this is the bar that the bumper bolts on to. obviously you access the bolts from the other side but i have highlighted in green where they are:
    I am not sutpid
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    cheers for ya help mate, where abouts are the bolts in the boot.... had a look and couldnt see any last time i tried to take them off.
  5. Default
    here you go. in green i pointed to the location of the nuts. the red arrows show you how to take the bumper off, just pull it!
    I am not sutpid
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Dont take your headlights out....
    Just take the whole reobar and aerofoil off...
    ie, just undo the massive 19mm bolts(x4) holding the irons on and pull the bar off.
    Much easier... you can take the irons off if you need to later... saves on alignment issues.
    aZk.
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Thanks heaps levymetal, and azkwazere, i might gie that a go coz everything i pull off that car never goes in the same...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Trust me do what Levy said. Alot easier, the 19mm bolts on the reo are tighter then a virgin, and really hard to get to. We took our bumper off using Levy's method, then remove the reo, to much ****ing around otherwise.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Oct 2007
    hey guys i have to take my back bumper off, i un did the 2 bolts that levy has pointed out, but the dam thing wont come off? its like the sides are still bolted in sumwher? or do i just have to pull like crazy?
    cheers.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by SUSS View Post
    cheers.
    Some people put screws on the sides to hold it, dont ask me why, i think its something to do with making it allign better. Check you dont have screws in the side. Also Sometimes its own weight can make it tight to, so get another person on the other side, and kinda lift up a bit and slide back if that makes sense, Your trying to take the weight off the bracket.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it has mudflaps on it, they are screwed through the bumper and into the body. Also, I think there are two screws in the top corners of the bumper where it meets the body above the rear wheels.
    Visit my Facebook page
    Jun 2005
    you guys have some odd methods of taking off the bumper. i got my bumper off without removing the headlights or the reo bar.
    - take off centre grille, you can get to the two centre bolts that way.
    - crawl under the front of the car, no need for a jack, and look for the other two bolts and get a socket wrench up there.
    simple. youll get if off in 5 minutes, and dont need to take apart the front of your car
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    May 2005
    .....SE Burbs
    The 19mm reo bolts (metal bar attached to plastic aerofoil) are easy as to get off, and cos there is a mounter and an aligner, it makes putting it back on alot easier.
    This isnt a hard process.
    I can strip my front end in not even 3 mins.
    aZk.
    89 VN Exec, 94 VR SS
    Dec 2007
    Yeah the pic Levy posted about the rear bar is simple, take off the 2 nuts and just pull and the bar comes off, yours maybe a little stuck like mine at first but only those 2 bolts hold the rear bar in, its just as easy to put it back on perfect too, just remember to retighten them up as hard as possible or the bumper wont look 100% straight
  1. VZ SV6/SS Bumper Removal
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-04-2012, 04:05 PM
  2. Wagon bumper removal
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 07:22 PM
  3. bumper removal
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2006, 04:36 PM
  4. Paint Removal off bumper
    By RichardW in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2005, 11:27 AM
  5. VT Rear bumper bar removal
    By R-ON in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2005, 07:23 PM
