Results 1 to 7 of 7
Thread: Need help finding fault
    Feb 2008
    Default Need help finding fault
    Hi Guys
    I need some help finding a couple of faults im having with my vn wagon. I have lot long ago replaced the series 1 engine with a series 2 which goes well but every now and then it starts to miss & the tacho goes nuts & the temp gauge shows the wrong indication & its hard to start like the battery is nearly flat. I have replaced the computer, coil pack & module from the square one to the three round ones. Any help would be great as it driving me nuts.
    FCV8
    VP exe
    Sep 2007
    probably do a diagnostic first.
    If your temp is going replace both coolant temp sensors in the engine.
    then on the other hand it could be....
    have you checked your battery and alternator????
    If your gauges are going haywire then its a sign the voltage is too low.
    low voltaGE WILL ALSO CAUSE IT TO MISS
    alternator and battery check.
    Gone Fishing...
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Check the earth cables from the battery to the engine and engine to body,body to battery.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    vn calais, vs clubsport #137
    Jun 2005
    Quote Originally Posted by KRUPTD View Post
    i think youll find this guy is on the money,
    could also be a problem with your voltage reg in the alternator.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by FCV8 View Post
    Hi Guys
    Ask my GF. She can find fault in everything!
    Reaper
    VN Executive S1
    Jan 2008
    Seaton S.A.
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Thanks vn calais manual,for the mention.
  1. Need help finding rambus ram
    By maginoodle in forum The Pub
    Last Post: 04-04-2007, 10:20 AM
  2. need help finding a sub!!
    By jay3178 in forum Car Audio
    Last Post: 11-02-2007, 10:48 PM
  3. Need some help finding a car...
    By ozstrider in forum General Discussion
    Last Post: 30-06-2006, 06:14 PM
  4. need help finding parts
    By totaldamage in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-08-2005, 09:00 PM
  5. Finding Manuals.
    By Bleaaargh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2005, 06:39 PM
