Got a weird problem, my LHS Rear indicator does not work at all, LHS front is blinking really fast, checked & installed new LHS Rear indicator bulb and still doesn't work, checked fuses also fine. RHS indicators work fine. When I press the button on the standard remote to Lock the doors, the locks go down then come back up again. Strange
Check for power at the indicator globe socket be sure there is power there.Being a VN VP try cleaning the contacts inside the socket.Remember the globe can only go in one way.For you central locking i would suggest looking at the drivers door actuator,if it has a problem it wont lock so the others wont lock either.
(KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
yeah from what ive heard the tail lights stuff up alot like vb through vk the contacts get really dirty to the point they don't make contact any more and you need to scrape the crud of the contacts with something hard I use a screw driver carefully to clean the contacts on mine trying not to damage them
