Results 1 to 8 of 8
Thread: Smoke coming from wheel?
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Smoke coming from wheel?
    Before you ask there the front wheels not back ones
    Well today i took my car out for a bit of a drive, after about, ill say 20 mins of driving, i stoped at the lights and noticed smoke coming from the front right wheel. I pulled over and took a look, wasent the engine so i drove the next k to get home.
    What i want to now what could cause this all of a sudden? the shocks and springs are pretty worn and i already got replacments for both not in the car yet.
    thanks
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    i was about to say new brakes where just put in! that would be it... im a idiot.... just a bit worried that i might of broken something cause it just started to happen.
    The Daily VN T5V6
    355 VN GRP A REP
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    if the brakes are new it could be some sort of fluid on dripping onto the disc and burning away.
    no longer a hoon by association - the commodore is gone
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    well i think it was just cause i was kinda testing the brakes out, ill see if it happens again.
    The Daily VN T5V6
    355 VN GRP A REP
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Check your disc faces from where the smoke was coming from,if they are a blue colour the calliper is hanging/grabbing (stuck on),easy fix is check the level of the brake fluid in the master cylinder,if it is overfull with the brake fluid the brakes wont work effectivelly and they will grab.Had experienced this a few days ago.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    VN Executive S1
    Jan 2008
    Seaton S.A.
    did you do the pads yourself cause I've done this myself got greasy hands on the discs and thats caused em to smoke along with the new pads bedding in not completely covered in grease just hand prints no detrement to braking to those people that are gonna say so!!!! if it still smokin after a good drive start to worry I mean a good long drive just keep a feel for the pedal and the normal stopping distance of your car. did you bleed the brakes after the pads were replaced, did you use a bottle and hose on the nipple or just let the brake fluid squirt out before tightening the nipple this can also get brake fluid on the caliper and disc which can cause the smoke I have also done this so yes before you guys say something "really bodgey" I agree but as long as you don't release the pedal before you tighten the nipple then it won't suck air
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    yeah i think they might be grabbing, ill have to take it back to the mechanic that replaced them, has new disc's all round aswell.
    The Daily VN T5V6
    355 VN GRP A REP
  1. Do you smoke in your car?
    By Kikki in forum The Pub
    Last Post: 18-02-2008, 12:03 AM
  2. Smoke from Steering Wheel?
    By Stranger in forum General
    Last Post: 21-06-2006, 06:01 PM
  3. Replies: 8
    Last Post: 01-10-2005, 01:54 PM
  4. VL Smoke
    By Milkman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-08-2005, 10:44 PM
  5. Smoke Coming Out Of Air Condition Vents
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2005, 07:24 PM
