Results 1 to 4 of 4
Thread: Map problem and manual conversion question!
    Vp calais, gemini
    Feb 2008
    melb, vic
    Default Map problem and manual conversion question!
    Hi, my vn series one v6 is throwing a MAP sensor code after i replaced the map (second hand one) whats the chances the second one is faulty or somthing else is wrong, when it starts it runs good for about a minute then the engine light comes on and it runs very very rough and stalls?
    Also i have a series one vn v6 manual conversion lined up, a wrecker told me the crank in a motor with an auto attached is different to the motor with a manual and i have to drop the motor and manual in and get rid of the original motor with the auto, anyone know if this is true???
    thanks for anyones help!!!!!!!!!
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    you just need a 8 bolt flywheel
    map sensor code, id get a new one for the sake of it, but first check the hose
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VN Executive S1
    Jan 2008
    Seaton S.A.
    the crank shaft is different between manual and auto in the series 1 I think the series 2 crank shafts are compatable with manual flywheels or auto flexplates
  1. Replies: 4
    Last Post: 26-03-2007, 11:05 PM
  2. VR manual conversion computer Question
    By str8up in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2006, 12:18 AM
  3. Manual Conversion Question....
    By g00gz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2006, 10:12 PM
  4. Question Regarding Manual Conversion Speedo wiring
    By Dub Alley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:39 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
